Hooking up FEL hose's
/ Hooking up FEL hose's #1
bx2670
Pilot Mountain N.c.
2013 Bx 2670
I, for the life of me cannot get the White and Yellow hoses to connect on the FEL. The Blue and Red connect fine, oh yeah it's on a Bx 2670 with LA 243 loader.
/ Hooking up FEL hose's #2
Make sure pressure is released on both sides of couplers. The tractor side is easy just cycle the stick in all directions with motor off. Sometimes the way you parked the loader will make it have pressure on a coupler so grab a rag and a punch then depress the plunger inside the coupler to release the pressure. (Wrap the rag arround the punch you could possibly get a big spurt of fluid)
/ Hooking up FEL hose's #3
And preferably something wood or plastic, in order to not damage the fitting.
/ Hooking up FEL hose's #4
Yep, I'm going with given advice so far. One of two things here, you've uncoupled them with a load on them (pressure) or you uncoupled in cool weather and are now trying to recouple in hot weather (fluid expanded).
/ Hooking up FEL hose's #5
I keep a dowel rod with a felt furniture pad stuck on the end of it stashed in my tool box.
Got them hooked up :cool2: ,they had pressure on them ,and yeah took off FEL mid Feb. Thanks for the advice !!
/ Hooking up FEL hose's #7
Glad you got it coupled back together. You'll not forget this lesson!!! :)
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
832795 (A61166)
832795 (A61166)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
