Hood Pins
/ Hood Pins #1
Aaron_D
Rhode Island
Bobcat CT230, Bobcat 325 Excavator, John Deere X300
I pulled off the hood to make it easier to work on a coolant leak on my CT230 and am having a very tough time lining up the pins for reassembly. Does anybody have any ideas or tricks? Ive tried inserting a tapered punch to line everything up but the pins seem to be fit very tightly. Before i grind a larger taper on the pins i thought i would ask.
Thanks
/ Hood Pins #2
Sounds like you are on the right track with a punch. Do you have a helper, that may make things easier.
/ Hood Pins
Played around with the tractor this weekend and wanted to follow up to maybe save somebody some aggravation. If you tilt the hood to maybe around 75 degrees, the pins will line up and inserting them is easy. Installing them or removing them at normal angles or less will be much more difficult.
2015Ford Escape SUV (A61574)
2015Ford Escape...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
PT Gravity Wagon (A64119)
PT Gravity Wagon...
3pt 4' Disc Harrow (A64119)
3pt 4' Disc Harrow...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
