Hood and side panel?
/ Hood and side panel? #1
Mrprez
Sneedville, TN
1964 Fordson Super Dexta, 2019 RK24 FEL and Backhoe
Ok, I know I am not this dense, but how do you get to the oil dipstick? I figured out how to open the top part of the hood, but how to get the side panel off? The manual is less than clear about how to do this. TIA.
/ Hood and side panel? #2
Probably should add your model. I dont need to remove a side panel on RK37
Yes, RK24, it’s listed on the left.
I made myself go out there and look at things until I figured it out. Surely, there is an easier way? Remove front grill, pop side panel off at the front and then slide forward to reveal the right side of the engine. Dipstick is to the right of the oil filter. Why are there two oil fill ports? One on top and one on the side?
/ Hood and side panel? #7
OK. great what is a RK 24? garden tractor? CUT. or a 100 hp giant? Not every body(outside of a multi brand dealer is aware off all the models)
It took me about two seconds to click on a new tab and search for a MT180D. Just saying!
/ Hood and side panel? #8
Two fill ports...ease of access. It is too bad the tractor manufacturer didn't have that as a concern.
/ Hood and side panel? #9
If you don’t know what a RK24 is how can u help him.
I’ve already found the answer to my question, thanks for the replies.
/ Hood and side panel? #11
I ran into that same problem and after looking around There are two clips in the front of the side panels. Pull them out an then pull the side panels to the front of the tractor. After you look at how it attaches everything will become clear. I had to raise the loader to access the side panels. I have a RK24 but I'm sure they are all alike. Hope that helps.
/ Hood and side panel? #12
Do the side panels serve any purpose other than a bit of protection and looks? Can I just run without them? Ya know like a real tractor 😀. Curious if they are needed for cooling. Removing them to check the oil is my only complaint with my RK24.
/ Hood and side panel? #13
Nowadays, I have to imagine that the panels are there both for cooling, as well as protection against intrusion by a branch, etc. Otherwise, they wouldn't be sealed completely with gaskets. (IMHO)
/ Hood and side panel? #14
That's the same design as my Mahindra, I bunged up the decal a tiny bit when, after tugging a bit, the clips let loose and the panel bashed into the loader cylinder. I am making a note to drape a moving blanket in there from now on, there's no sense in me making it look old before its time.
/ Hood and side panel? #15
Make sure you get both the clips back on. I didn't and the panel came loose dropped down and when I brought the bucket back down the hydralic fitting on the lift cylinder smashed the crap of it. Not covered under warranty. New one 165.00.
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
