Hood and side panel?
   / Hood and side panel? #11
I ran into that same problem and after looking around There are two clips in the front of the side panels. Pull them out an then pull the side panels to the front of the tractor. After you look at how it attaches everything will become clear. I had to raise the loader to access the side panels. I have a RK24 but I'm sure they are all alike. Hope that helps.
   / Hood and side panel? #12
Do the side panels serve any purpose other than a bit of protection and looks? Can I just run without them? Ya know like a real tractor 😀. Curious if they are needed for cooling. Removing them to check the oil is my only complaint with my RK24.
   / Hood and side panel? #13
Nowadays, I have to imagine that the panels are there both for cooling, as well as protection against intrusion by a branch, etc. Otherwise, they wouldn't be sealed completely with gaskets. (IMHO)
   / Hood and side panel? #14
That's the same design as my Mahindra, I bunged up the decal a tiny bit when, after tugging a bit, the clips let loose and the panel bashed into the loader cylinder. I am making a note to drape a moving blanket in there from now on, there's no sense in me making it look old before its time.
   / Hood and side panel? #15
Make sure you get both the clips back on. I didn't and the panel came loose dropped down and when I brought the bucket back down the hydralic fitting on the lift cylinder smashed the crap of it. Not covered under warranty. New one 165.00.
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
