honda fc 600 tiller keeps flooding with oil
/ honda fc 600 tiller keeps flooding with oil #1
yelizardking
honda tiller
i have a honda fc600 tiller that had a pull cord that was stuck, i pulled out the spark plug and the cylinder was full of oil, i blew the oil out and pulled on the cord about 20x replaced the spark plug and it wouldnt turn on, u pulled the spark plug out again and spark plug and cylinder was full of oil, i did the same thing and blew it out, and i kpuuled on the cord again and it got fukll of oil again, i repeted the pulling of the cord and blowing of the cylinder about 4x and it seemd like the oil keeps on coming, am i doing something wrong?
-thanks for the help
/ honda fc 600 tiller keeps flooding with oil #2
Welcome to TBN. :)
/ honda fc 600 tiller keeps flooding with oil #3
Good to have you aboard. I am unable to assist you with your inquiry, but hopefully another member can. :tractor:
/ honda fc 600 tiller keeps flooding with oil #4
Our honda generators at work will do this. Supposedly if you leave the gas on with the tank being above the motor and it being a overhead valve the gas will seep into the oil causing them to mix. If we shut the gas off after use no problems.
thanks mattridessleds! that did the trick!!! awesome!!
/ honda fc 600 tiller keeps flooding with oil #8
The overhead tank ios not the problem, cause the fuel has to pass the carburettor before it will reach the cylinder.
I would take a look at the flood in carb, maybe theres is a hole in it and it cannott swimm to close the needlevalve. This valve is gummed at its peak, also the gum can be wornout and the valve will not close.
I am wondering about oil at the top of the piston. That would mean, that there are some probs with the piston rings.
/ honda fc 600 tiller keeps flooding with oil #9
The raw gasoline leaks into the crankcase, and raises the level with diluted oil. Pull the oil fill plug and check the level. It is best to cut off the fuel and let the carb empty itself as the engine burns the last bit. gum can still form in the bottom of the bowl. Thanks to ethanol, more gumming....
/ honda fc 600 tiller keeps flooding with oil #10
No. This Problem is only known by B&S engines with horizontal Cylinder and only, if the outlet valve is opendend. The needle valve didnエt close for any reasons, the carb will be flooded over and the gas getエs in to the crankcase. If this happen, it will cause thinner and more oil in the crankcase, but it will not flood the whole cylinder.
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
JOHN DEERE 7230R TRACTOR (A60430)
JOHN DEERE 7230R...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
