Honda engine shaft for pump
   / Honda engine shaft for pump #1
oldforestor
Bronze Member
Golden Triangle KY
Kub M8560 Orange Millenium Falcon, Kub M4050 wonderful dependable relic
I have a Honda 5hp motor from a dead pressure washer. I want to put a transfer pump on it.It has a 7/8" horizontal shaft. All the trash and transfer pumps I've seen have a 3/4" shaft. ?????
Are there no pumps for 7/8 shaft????
   / Honda engine shaft for pump #4
For occasional basic (crude) coupling you can also use a short length of 3/4" hydraulic hose and either clamp onto the shafts or even drill for 1/4" hardware.
I have even seen this approach on some commercial applications that did not carry all that much torque.
For a transfer pump it would work IMO.
But I agree that Lovejoy style couplings is the best method.
Thanks for replies. I'm trying to fit the transfer pump onto the existing cart thing so inserting the shaft into the pump is a space save. I'm mulling over cranking it up and putting a file or grinder to it, then reslotting it with a dremel?
   / Honda engine shaft for pump #6
New Holland uses that on the crank arm to adjust the kicker speed.
Aaron Z
   / Honda engine shaft for pump #7
Make sure that the shaft has Imperial dimension as opposed to Metric. Closest Metric to 7/8 is 22 mm.
8ft Fork Extensions (A50322)
8ft Fork...
2015 Ford F-550 4x4 Knapheide Service Truck (A50323)
2015 Ford F-550...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2008 Toro Workman 200 Sprayer Cart (A50322)
2008 Toro Workman...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
