Honda Compact Tractor Issue
/ Honda Compact Tractor Issue #1
nedbrod
Oriental, NC
honda 6522
I have a Honda H6522 compact tractor. I recently broke the connector cable for the shift linkage. It appears that this part is obsolete/discontinued and I have been unable to locate one. I hope that someone out there in this forum may have an idea where I might find used parts for this tractor or has some recommendation of some bone yard that might have these tractors lying around. Thanks for any help that can be provided.
/ Honda Compact Tractor Issue #3
How about having a shop weld it back together?
If you remove both pieces and can post a picture, I’m sure you will get some good advice on if a repair is possible.
“Edit”Rereading your post, a cable most likely couldn’t be welded, but a picture of the part may get you a possible solution.
Mike
/ Honda Compact Tractor Issue #4
From Craigslist/Northwern, WI
/ Honda Compact Tractor Issue #5
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
