Honda Compact Tractor Issue
/ Honda Compact Tractor Issue #1
nedbrod
Oriental, NC
honda 6522
I have a Honda H6522 compact tractor. I recently broke the connector cable for the shift linkage. It appears that this part is obsolete/discontinued and I have been unable to locate one. I hope that someone out there in this forum may have an idea where I might find used parts for this tractor or has some recommendation of some bone yard that might have these tractors lying around. Thanks for any help that can be provided.
/ Honda Compact Tractor Issue #3
How about having a shop weld it back together?
If you remove both pieces and can post a picture, I’m sure you will get some good advice on if a repair is possible.
“Edit”Rereading your post, a cable most likely couldn’t be welded, but a picture of the part may get you a possible solution.
Mike
/ Honda Compact Tractor Issue #4
From Craigslist/Northwern, WI
/ Honda Compact Tractor Issue #5
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
2025 Kubota L2502HST (A64119)
2025 Kubota...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
John Deere 995 (A64126)
John Deere 995...
