honda atv starter?
/ honda atv starter? #1
ohio farmer04
new holland tn
i have 1999 honda with brand new battery sometimes it will not start
do i need a new starter?
/ honda atv starter? #2
Do you leave it sit for extended periods? I have 2 1999 Honda 450 ATV both will drain a battery if they sit for a while without running.
/ honda atv starter? #3
if batt voltage is good
check for corrosion, esp on plugs in batt compartment
/ honda atv starter? #4
I have not been all or done all......yet; but I have never heard of a honda starter going out.
Will it turn over? Sometimes (on a slope), I have to rock my quad back and fourth a little to get it into neutral.
I have heard of armatures getting worn on the sides where it lands after years and years of starting. It develops a pattern (so to speak). Plus there is only 360 degrees of surface for an armature to land on. The odds of it landing on the same spot are pretty good.......
Keeping all the connectors shinny is real important. I rarely let my 350 ES sit but I run a 5 watt solar charger on my wife's craftsman tractor; man, that thing cranks super strong every time.
Other idea; it may be a neutral safety switch?
Hope this helps
/ honda atv starter? #5
I had a Honda 4 wheeler years back and had starter issues a few times. It was hard on brushes. If the suggestions from the previous posts fail, take the starter to a good repair shop. They would install new brushes for me at a fraction of the cost of a new starter. If I remember correctly, they had to modify brushes that they had to fit instead of getting them from Honda.
/ honda atv starter? #6
I had the starter replaced on my 2000 Rancher two years ago. $158.00 including parts and labor.
/thank should i take honda dealer?
when warm runs
should look at new ones?
/ honda atv starter? #8
I would call some dealers and get an estimate on a starter. Some dealers charge pretty high prices. My 2000 Rancher runs 365 days a year winter and summer. My wife uses it to hay the horses outdoors twice a day.
2017 Caterpillar 336F Hydraulic Excavator (A61572)
2017 Caterpillar...
1057 (A63291)
1057 (A63291)
2013 Mercedes-Benz GL450 AWD SUV (A61574)
2013 Mercedes-Benz...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
