Homes… Your Thoughts… Old or New?
   / Homes… Your Thoughts… Old or New? #61
Post and beam has been trendy for a while Mr. Fuddy...this too will change! And it's comparatively expensive to build. I'm like Mr. Winterdeere, finding old farmhouse styles being very welcoming!
Beauty is in the eye of the beholder...and lots of somebody's wanted this in 1975...View attachment 3257418
When I was in High School around that time I took a drafting class.
Once we were taught the basics of drafting we were to design and draft our dream house.
Almost to the person everyone had a sunken living room.
I always thought they were dumb.
   / Homes… Your Thoughts… Old or New? #62
Our house is an 18th century cape with low (7') ceilings and correspondingly low ridge. When we put on an addition we had the aesthetic consideration that the addition ridge not be higher than that of the main house. Additionally, we wanted the height to display a family heirloom grandfather clock. Accordingly, there was an 8" step-down to a 20 x 20' family room--a sunken living room that proved a stroke of luck when my toddler sons started playing with Legos. The errant Legos stayed in the LegoPit.
   / Homes… Your Thoughts… Old or New? #63
Wasn't that a design fad at one time? Trouble is, once the fad goes out of style, you're stuck with a house that's kind of a white elephant.
When I was in my early teens, my aunt & uncle had a house that looked like a ranch house on the outside, but had 3 levels inside...almost like an upper story & a lower story on one side and a room or two that were midway between the two on the other side. This would have been in the early 60s. Even then I thought it was a dumb layout.
   / Homes… Your Thoughts… Old or New? #64
I’m working on a remodel job now where we built the sunken living room back to level. I think a sunken room is pretty dumb. Why would you want to make a fall hazard for absolutely no benefit?
   / Homes… Your Thoughts… Old or New? #65
I had to look them up as I had no clue what people were referring to. That sounds like more expense in building, and an oddity to keep heat from circulating well.
I am naturally cheap so come from the school of keep it simple.
   / Homes… Your Thoughts… Old or New? #66
By "attention to detail" are you referring to fussy stuff like carved woodwork, embossed tin ceilings, gingerbread outside trim, etc? Not all old houses were built that way.
Yeah, fussy stuff. I loved pressed tin ceilings. My wife nixed that idea for the main room with the vaulted ceilings. I love bead board too. That idea also got nixed but it may still happen. You are correct though, not all old houses are full of fussy stuff. Still, even they can have character from use and gems like wavy glass. Wavy because it was cheaper back in the day, now it's expensive.
Eric
   / Homes… Your Thoughts… Old or New? #67
Yep, fall hazard. As one who has fallen down stairs more than once I totally agree. Broke three ribs recently falling down the basement stairs.
Eric
   / Homes… Your Thoughts… Old or New? #68
...gems like wavy glass. Wavy because it was cheaper back in the day, now it's expensive.
That's the second claim about wavy glass in this thread, and this one is at least partly true. The other claim was that the glass is wavy because it flows over time, which implies it was once perfectly planar and clear, which is less likely.
The size of the divided lights in a window is also something that changed quite a bit with time, and some historians have tried using this to estimate the age of old houses. But at least in the case of my house, it proved to be an unreliable method, with their best guesses later proven wrong by hard documentation. The reality is that there has long been a range of what's available, both with regard to size of lights and clarity, for those willing to spend more or less. Seeing a divided-light double-hung window with 8x10 inch panes might cause one to think the house must be 19th century, ignoring the fact that those in the late 18th century could buy panes that large, if they had no care as to the cost.
Moreover, sash could be replaced within existing windows, which may in fact be the case in my house. We know the window frames all date to 1775, and the sash are all identical, making one assume they're also 1775. But it is possible they were all replaced at the same time, re-fitting sash of the same size but fewer and larger panes into the old frames, during a mid-1800's rennovation.
Our original glass is wavy enough that I can tell when there's something or someone in our yard, but I could never actually identify the person without finding a newer replacement pane to peer through. Looking through a few of our waviest windows you could have trouble even telling if it's even a person or a deer! :D
If anyone wants to argue about glass flowing over time without being heated, read this:
Spent a fair amount of time in Materials/Plastics back in Engineering class with the distinction between amorphous and crystalline emphasized…
The question "Is glass solid or liquid?" has no clear answer.
In terms of molecular dynamics and thermodynamics, it is possible to justify various different views that it is a highly viscous liquid, an amorphous solid, or simply that glass is another state of matter that is neither liquid nor solid. The difference is semantic.
Even in terms of its material properties, we can do little better. No clear definition exists of the distinction between solids and highly viscous liquids. All such phases or states of matter are idealisations of real material properties.
Nevertheless, from a more commonsense point of view, glass should be considered a solid since it is rigid according to everyday experience.
The use of the term "supercooled liquid" to describe glass still persists, but is considered by many to be an unfortunate misnomer that should be avoided.
In any case, claims that glass panes in old windows have deformed due to glass flow have never been substantiated. Examples of Roman glassware and calculations based on measurements of glass visco-properties indicate that these claims cannot be true.
The observed features are more easily explained as a result of the imperfect methods used to make glass window panes before the float glass process was invented.
   / Homes… Your Thoughts… Old or New? #70
Yeah, I never bought the whole "glass flowed" theory either, especially since many of these old windows the ripples are vertical, implying that the glass flowed horizontally.
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2387 (A58376)
2387 (A58376)
2018 John Deere HPX 615E (A57149)
2018 John Deere...
2020 Kenworth T370 T/A 4,500 Gallon Water Truck (A56858)
2020 Kenworth T370...
Ford F-650 Mason Dump Truck (A56858)
Ford F-650 Mason...
