Homes… Your Thoughts… Old or New?
   / Homes… Your Thoughts… Old or New? #151
People call it the new old place, with the theme designed around 1918, back before power tools and air nailers.
Reminds me of one of my parents' houses. The very last build contract taken by a locally-famous builder, who was in business ca.1910 - 1950's.
He came through our house once in the 1980's, as an old man. While in the basement, he was looking up at the beaded T&G yellow pine subfloor above, laid at 45 degrees to the joists, and shaking his head. He just said, "I couldn't afford to build a house like this today, if I wanted to."
The last project done in that house, before mom sold it, was re-doing the tiled floor in one of the shower stalls. She asked around and found the best tile man in the area. He showed up, and was well into his 70's. Mom worried how he was even going to do the work. At the end of the first day, as he was saying goodnight, he mentioned to my mother that he was the one who did the original tile work on all of our showers and bathrooms, 45 years earlier. :ROFLMAO:
This has been my gripe with refrigerators. We've been in this house 14 years, and I've honestly lost count of the number of kitchen refrigerators we've been through. The last one failed inside warranty, something like 20 months old, but warranty service was so slow that I just replaced it.
Sure, maybe they contain less refrigerant than older units, and use slightly less electricity. But when you need to manufacture and then landfill a new one every second year, I'm not convinced the net savings is in the right direction, no matter how it's measured.
Same observation by me too…
Neighbors had a nice Whirlpool Washer Dryer set they got rid of to take advantage of incentives for water and energy efficiency…
They bought a expensive Neptune and I got the old ones…
Nineteen years later zero issues with the Whirlpool but they can’t say the same… on set 3 now and more than once said they would be way ahead had they kept the old Whirlpools.
I can’t tell you how many friends paid good money for LG refrigerators and then experienced compressor failures… mostly out of warranty but then LG said extended parts but customer pays labor.
Again, my hand me down Amana from the 70’s just keeps working…
And what’s with the flat screens have a 5 to 7 year typical life when old CRT would go 20 or more…?
I still have the original Carrier furnace/AC 1990 needing one igniter but no one I know gets more than 12-15 from their new units…
   / Homes… Your Thoughts… Old or New? #154
Has anyone here insulated a 1860s house? How did you go about it and was it worth it?
   / Homes… Your Thoughts… Old or New? #155
Yes, and yes.
Balloon-framed construction? Blown-in polystyrene beads used to be a popular way to do that, in fact our "third kitchen" addition (framed 1890's) was insulated this way by a prior owner. It works well, in that we had to empty one stud bay of the beads to do some work a few years ago, and not having ever re-filled it, I notice how much colder that one stud bay is than the rest of our kitchen.
I'm less enamored with the method of blue foam board on masonry walls, the victorian I owned previously was insulated that way by a prior owner. It works, but there are down-sides, the benefit less extreme.
   / Homes… Your Thoughts… Old or New? #156
In the 1840s farm house I stripped one room to the studs and refinished. It had been my old bedroom, and in the coldest winters if I didn't leave the door open it could easily be in the 20s at night(-40outside), with frost on the walls, even with forced air heat. It had balloon framing, horse hair plaster and of course zero insulation. In it's prior life it had been the "bath" room. There is a hole in the floor for the drain to the outside, a patched hole in the wall where a pipe led to the kitchen hand pump and cistern, and a 1x18 plank nailed on the ceiling where a curtain had hung. I put R15 batting in the 2"x4" stud walls, fire breaks top and bottom, R60 in the attic above, visqueen vapor barrier all around, new drywall and paint, new hard maple trim to duplicate the previous. The windows had already been retrofitted with new double hung casement inserts.
Was it worth it? Last winter it was down to -20, and that room was the warmest in the house. One heat run, 50ft from the furnace through uninsulated crawl space was more than enough to heat the room.
   / Homes… Your Thoughts… Old or New? #157
I have had houses from the 1920s to 1980s
My current house , built in the 80's was designed by the previous owner and he was fastidious on everything except electrical.
Steel beam support and most walls are supporting structures.
My 1920's house was built heavy, but not well.
The biggest problem was some identical houses on my block slid off the foundations!
My last 1980's house was built and insulated well, but had cheap windows. and gaps under the eaves and under the bottom of the cedar planking.
My FIl house was built in the late 1700's into the 1800's and when he sold it, we did not buy it.
That house needed a complete redo, including termite infested hand hewn support beams in the dirt basement. Needed new wood around the roof and to have the slate roof fixed.
Someone else took on the work and it almost bankrupted him.
I am sure he spent many times what it cost to buy just to get it into decent shape.
My Uncles house built in the 1800s (the added rooms had newspaper insulation with some readable from the 1860's) was all lathe and wood on typical stone foundation.
The PO had put a pot belly stove on the second floor, and the weight over the decades sank that part of the house.
Eventually my uncle got tired of putting money into it and sold it. They knocked most of the house down and only kept the 1860s part.
The original front room had been the town library around the early 1900's and had books from the 1890's up.
Both my FIl and my Uncles houses were hand built by their owners and other locals.
Both required huge maintenance, windows that would not open, poor insulation and lots of drafts.
I am happy with my 80's house now, least amount of work so far, just some roof leaks around the stone chimney and a few electrical glitches.
My 1920s house also had been redone quite a bit by the previous owner, he did the work himself and he had no idea how to do it.
I had to rip out walls, bathroom floor and a staircase to fix his inept updates.
Staircase with supports only on three sides, open live wires stuffed into spaces as they got closed up. Roof with multiple layers of wood and shingles.
When he redid the downstairs shower, he reused the tub and drain pipe, added a layer of tiles and screwed back down the drain, so there was a gap under the tub where water rotted out the woods holding up the floor. I figured it out before I fell through, but just barely, removed most of the 2x4s under the shower without tools !
Inspections are key and I hired good ones and worked with them on last two houses.
Did not want any more surprises!
So doing your due diligence with inspections and knowledgeable people is more important than age.
   / Homes… Your Thoughts… Old or New? #158
My FIl house was built in the late 1700's into the 1800's and when he sold it, we did not buy it... Someone else took on the work and it almost bankrupted him.
Speaking of which, how's my uncle's old place coming along? :D Pic's welcome!
I had plans to buy that house, but the timing did not work out in my favor, and my wife has outgrown living in the "old house construction zones" to which I subjected her the first decade of our marriage.
   / Homes… Your Thoughts… Old or New? #159
I had plans to buy that house, but the timing did not work out in my favor, and my wife has outgrown living in the "old house construction zones" to which I subjected her tbuildinghe first decade of our marriage.
They are redoing the building to the right now.
I will see if I can get pics later or tomorrow.
They are also working on the landscaping a lot.
Can't imagine the amount of money they are pouring into it, but they so far are keeping the look and feel.
There is another house around the corner that just changed hands and they are rebuilding the barns, also keeping the look and feel.
It's nice to see that.
When they redid my FIl house, they changed the windows to more modern ones and the roof to regular shingles from the slate, so it looks very different.
   / Homes… Your Thoughts… Old or New? #160
Cool! Yeah, you gotta keep the original windows.
We have all old sash, seemingly original to the 1775 addition, and maybe even two casement windows that go back to the older 1730's house that the current building sits upon. It seems some or most of the frames have been replaced once in the 250 - 300 years since, which is pretty good, considering modern "replacement windows" never seem to last more than 30 years.
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2021 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
