homemade weight for front of tractor
   / homemade weight for front of tractor #21
Radman,
I think I understand your thinking about the tractor not minding the little bit of extra weight on the nose. Here is a picture of the front of my "other" tractor with the little bit of weight that it carries. Althought there is no FEL, (Spiveyman has my loader) it still carries a lot of weight up there. There is also a wear factor (of almost 0) when weights are on versus running with weights off. I seem to remember that there is almost 1300 pounds on the nose of that tractor, give or take a few pounds.
David from jax
Thumbnail to help the dialup people...
   / homemade weight for front of tractor #22
Here weights I made for my Rounder skid steer 12" wheel weights. The outer shied is from a old brake drum from a S-10 filled with lead I got free from a tire shop. Each are 85lbs that will fit in most lawn tractor with a 12" rim. I cut a grove out for the air valve and welded tubes to bolt on rim. I use a frying pan and LP burner to melt the lead. Then I made it so the nuts where counter sunk in the weight so nothing could hang up on anything.
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Cushman Electric Cart (A55851)
Cushman Electric...
