Homemade Hydraulic Toplink
/ Homemade Hydraulic Toplink #1
catdozer
Platinum Member
john deere
So while in the shop looking for a replacement cylinder for the grapple (snapped the rod) i found a 2.5 bore 1 1\8 rod 15in stroke cylinder. It was missing the clevis ends so i thought it would be a good cylinder to make a toplink. But it was a 15in stroke. I went ahead disassembled and cleaned everything and measured it all out and put it on the band saw and cut off 5 inches of the tube.
Put it on the lathe and put a inside bevel on it so the ends slide in. Everything fit great had about a 9 1\2 stroke. I was pretty happy i picked up toplink replacement ends for 8.99 each. I got the one on the cylinder end welded all up. Cut the rod off and welded that end on. I had 1\2 hoses that fit with couplings. This was in one day. Today i need to pick up new bolts to hold the cylinder together.
I only got a few pictures but they wont load. Can put then on later.
But in all i will end up with a hydraulic toplink for about $30-$40
if it fails, Well wont be out much as i can still cut the ends off.
/ Homemade Hydraulic Toplink #2
Neat, the level of fab work on this site is often pretty impressive
Well heres it all hooked up. Just need a coat of black paint and im good to go. Went and played around with the box blade, cant wait to try out the landplane with it
/ Homemade Hydraulic Toplink #4
I think about making one everytime that I have to adjust the turnbuckle!
I planned to just have it manual adjust with lines going to a small reservour with a shut off valve to open and adjust.
/ Homemade Hydraulic Toplink #5
Great work !! I built mine with a 2 1/2" cylinder and have been very happy with it for the last 8 years. I think you'll like the capacity of that size cylinder. I had bought my cylinder from Surplus Center and cut the clevis ends off and bought the swivel ends from Tractor Supply to weld on. I also put a Prince pilot operated check valve on mine to cover any valve leakage or possible hose blow-out with a heavy piece suspended on the 3pt. I paid as much for that valve as I had in the cylinder & swivel ends but oh well... I know the implement will stay where I put it, hydraulically. Doing it all over again I might not put the valve on there to save a little money. I wouldn't own a tractor without a hydraulic toplink since having this one !!!
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
(60) 2"X8"X12' METAL FRAME WALL STUDS (A60432)
(60) 2"X8"X12'...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A60432)
UNUSED FUTURE SB45...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
