homemade gooseneck conversion
   / homemade gooseneck conversion #21
Hey bdog
I like your idea, here is what i am working on and tell me what you think. I bought a 20' gooseneck stock trailer, I am going to make a flatbed gooseneck trailer out of it, it has 7000lb axels under it that is 14000lbs, After stripping all the mettal off of it i found out the angle iron is very rusty, here is what i started to do, I put in 4" square tupe 3/16" thick, they run the 20' of the trailer and two pieces from them up to strenghten the goosneck, I also have the BW gooseneck hitch turnover ball, now with the 4" square tubes in i have 4" angle 1/4" think i am going to put in as cross memers, 2' apart, Tell me what is stronget squre tube or C channell you said you had 6" c channell but i think the square is stronger, Please fill me in what you think and Thank you!
   / homemade gooseneck conversion #22
I will post up some pics of the conversion when done. It is looking good.
I'd like to see pics of the process too if I could. I've toyed with the idea of doing the same thing with my old beat up tilt trailer. I have new axles coming for it this week, and I'm either going to put a new A-frame tongue on it or a gooseneck tongue. If I go with the A-frame, I have an equalizer hitch that I'll use. What are you using for the gooseneck coupler? Any I've seen are more money than what you are figuring for the whole project.
I can appreciate the well intentioned excess of caution expressed by other posters. But, I believe I understand your situation, and I think you're making a good decision. You're going to put the weight where your truck can handle it without overloading your axles or anything else (including your wallet). Plus I love pulling a gooseneck.
I know you're pretty far into this project, but make sure you build the gooseneck plenty high. It doesn't take much of a dip or bump to crunch the sides of your truck bed with a shallow gooseneck.
   / homemade gooseneck conversion #23
Hey bdog
You mean a livestock trailer ? are you sure that the frame will handle the rated weight, without additional support of the superstructure ? Most manufacturers make a trailer frame a lot lighter when there is a stiff superstructure. Some refrigerated trailers dont even have a frame at all..
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
