Homemade 3pt Snowblower
   / Homemade 3pt Snowblower #11
Excellent work!!!
Love that gear box too. I can't tell from the pics but is there a way to adjust the gear lash? If not how did you figure out the distance required between centers to have the correct lash. I've been toying with the idea of running my rear mount snow blower on the front of the tractor, driven by the rear PTO. But that would require a reversing gear box like the one you made and I would like to know how to determine the correct gear spacing.
I'm fortunate to have access to a visual measuring machine at work. I setup the gears gently pressed together (no lash) and had the tech measure the center to center distance and it was 4.80000 (yes to 5 decimal places). I added .010 for clearance and machining variation, ended with very little play. Will it last for 100,000 miles? Probably not, but it should outlast everything else on the blower.
Prior to the visual measuring machine, I had thought of grinding some close fit pins and using them to establish center lines. Then use the same process of measuring the gears gently pressed together.
   / Homemade 3pt Snowblower #13
Excellent work!!!
This is an idea for reversing the pto direction for a front mounted blower I found years ago.
This might give you some ideas which do not need specialized machining skills.
Dave M7040
Ooo I like that.
   / Homemade 3pt Snowblower #15
Dave M7040
Thanks Dave. Funny thing is, I've already got that pic saved on my desktop from some previous research I had going on about a year ago, for the same topic.:)
John
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
JOHN DEERE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN DEERE 1000...
2007 John Deere 6215 (A57148)
2007 John Deere...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
VERMEER V6500 COMBO TRENCHER (A52708)
VERMEER V6500...
2026 Quality Steel 5x8 S/A Utility Trailer (A56859)
2026 Quality Steel...
