Homebuilt Forage Wagon.
/ Homebuilt Forage Wagon. #1
R W
Has anyone built there own self unloading forage wagon.
/ Homebuilt Forage Wagon. #3
A local contractor runs a four axle forage wagon behind a Magnum. The first, 3rd and 4th axle are steered by a pushrod which is mounted with a toplink ball joint next to the drawbar. I think they take about 60m3 (82 cu.yard) of silage with it, and with over 3 ton drawbar weight, it gets through a reasonable wet patch too.
Another contractor put a forage box on a 430hp Ginaf 6x6 offroad truck, they take about 45m3 through allmost any terrain, clay or marsh.
http://www.youtube.com/watch?v=iG6sEgUVQtQ
You can get a lot of universal gearcases from Italy or Germany: Comer, Rochling, lots of brands.
/ Homebuilt Forage Wagon. #5
Thanks for the negative reply.
Actually, I think "Why?" is a perfectly valid question. Many things 'could' be built on a DIY basis, but don't make sense unless feaures not commonly available on production units are desired. So I will also ask- Why?
Actuall Many things 'could' be built on a DIY basis, but don't make sense unless feaures not commonly available on production units are desired. Why?
Cost, Size & Availability.
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
FORD 4500 TRACTOR (A64280)
FORD 4500 TRACTOR...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
