Homebuilt Forage Wagon.
/ Homebuilt Forage Wagon. #1
R W
Gold Member
Has anyone built there own self unloading forage wagon.
/ Homebuilt Forage Wagon. #3
A local contractor runs a four axle forage wagon behind a Magnum. The first, 3rd and 4th axle are steered by a pushrod which is mounted with a toplink ball joint next to the drawbar. I think they take about 60m3 (82 cu.yard) of silage with it, and with over 3 ton drawbar weight, it gets through a reasonable wet patch too.
Another contractor put a forage box on a 430hp Ginaf 6x6 offroad truck, they take about 45m3 through allmost any terrain, clay or marsh.
http://www.youtube.com/watch?v=iG6sEgUVQtQ
You can get a lot of universal gearcases from Italy or Germany: Comer, Rochling, lots of brands.
/ Homebuilt Forage Wagon. #5
Thanks for the negative reply.
Actually, I think "Why?" is a perfectly valid question. Many things 'could' be built on a DIY basis, but don't make sense unless feaures not commonly available on production units are desired. So I will also ask- Why?
Actuall Many things 'could' be built on a DIY basis, but don't make sense unless feaures not commonly available on production units are desired. Why?
Cost, Size & Availability.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
213135 (A64276)
213135 (A64276)
UNUSED SDLANCH SDLC1220-12'X12' HIGH END CARPORT (A65055)
UNUSED SDLANCH...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
2022 EZ-GO ELITE...
