Homebrew Grill Guard
/ Homebrew Grill Guard #1
valleydweller1
Willamette Valley, Oregon
Kubota B7510
Hi all,
I recently broke out the grill on my BX2230 with a log that fell from the FEL. I have ordered the replacement parts for the grill, and have decided that a grill guard is in order. I would buy one, but they're expensive and I'd rather weld up my own.
Does anyone have any thoughts/experiences/pictures of what they've done or seen done with grill guards?
/ Homebrew Grill Guard #3
Here's one I made from what I had on hand.
/ Homebrew Grill Guard #4
Second pic of lower part.
Don't pay no attention to the impromptu spacer. I'll correct the close tolerances later.
ron
Ron,
Thanks for the pics. I had planned on using flat plate for the bottom, but I like your use of the angle with the shackle. What are the dimensions of your parts? I have some 1/4"x2 1/2" bar for the uprights and some 1/4" wall 1 1/2" diameter tubing for the crossbars.
/ Homebrew Grill Guard #6
I think the bar is 1/2 x 2 and the angle at the bottom is 3x3x3/8"
It's what I had on hand. I haven't tested it yet, but hope it is strong enough to protect the grill.
Ron
Brown,
That looks like a good unit. In truth I just want to get some more time on my welder. It's new, you see...
/ Homebrew Grill Guard #10
Ok I wish I had a press brake. I drool over those, but at $5K for a cheapy one, I use the old stand by oxy acetelene rosebud with the iron in a vise.
I've done enough iron stuff to try to learn to control the runout. I made the bends, checking with a square to get them close, and let the runout show up on the legs.
Then I cut the legs to length so it would look nice and square.
Still pondering whether to fab a big "R" to put on the cross piece to personalize my tractor......................
HAve fun,
ron
/ Homebrew Grill Guard #11
I used angle iron and perferated metal ( not expanded.. perf metal is about 1/16 thick and has holes in it.. kinda like strainer material ).. for a NH 1920.. worked nice..
Soundguy
/ Homebrew Grill Guard #12
Ron,
Ah, the run-out...good tip 'cause I ALWAYS screw up there! In my case I'd have to make the tractor shorter...Ha! /forums/images/graemlins/grin.gif
In your case, definitely go with the big "R"!
/ Homebrew Grill Guard #14
This is the one I made for my MF 1240 just before painting. I used 1/4 x 2" and drew up the dimensioned layout on my computer, thats the sheet next to the new grill.
/ Homebrew Grill Guard #15
I just made one from 3" channel. The heavy stuff, 6# if I recall. It goes above the headlights (and above the hood), then has an opening for the lights. The bumper is also 3" channel. I don't have a FEL so the bumper keeps the junk off the axle a bit. While at the scrap yard they had a 4' piece of 4" channel. For added weight I welded the 4" over the 3". You can only tell there are 2 from the sides or back. Not as pretty as a curved piece if flat metal and pipe but it'll work ok I hope. I'll post a pic tomorrow, all my pics are at eh office.
Rob
/ Homebrew Grill Guard #16
Syncro, That brush guard looks "factory." Nice work. Love the head light cutouts.
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2006 Ford F-350 Pickup Truck (A62613)
2006 Ford F-350...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
2022 EZ-GO ELITE...
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
