Home weather station suggestions
   / Home weather station suggestions
I have an ambient weather station. I started it with lithium batteries and I think it's been 2 years now. I probably need to get up and replace them.
Love the weather station, even my wife looks at it and follows the weather.
   / Home weather station suggestions #133
The Tempest is down to $288.50. I like how it has no moving parts. Solar powered battery.
Tempest Weather System with Built-in Wind Meter, Rain Gauge, and Accurate Weather Forecasts, Wireless, App and Alexa Enabled Amazon.com: Tempest Weather System with Built-in Wind Meter, Rain Gauge, and Accurate Weather Forecasts, Wireless, App and Alexa Enabled : Patio, Lawn & Garden
I'd love to like it. I love the no moving parts side of it. However, around here, it appears to be less than accurate. I have neighbor who has one and his readings are at odds with basically all of the nearby weather stations. I had rather hoped that firmware updates might have improved things for him, but not so far. I will say he was an early adopter.
I had my Davis Vantage Pro 2 overhauled at the factory after 17 years of great service. In that time, I had replaced the solar/ battery pack once, and I had upgraded the rain cone to their bird free version, but that was all. The cone spikes really helped keep leaves out of mine. The overhaul price was very reasonable for what amounted to a basically new weather station, and the turn around was only a couple of days, though I'm sure that fluctuates with the demand.
All the best,
Peter
   / Home weather station suggestions #134
I have had a Davis Vantage Pro 2 for about 13 years, my only complaint is the 1990's looking data logging software.
   / Home weather station suggestions #135
Yeah, probably ought to replace the batteries in ours too, also lithiums but they're 2-3 years old.
Got this mostly for the wife, she'd wanted one for a while. Ours is standalone, no internet connectivity. Didn't see the need.
   / Home weather station suggestions #136
I have an AcuRite 5-in-1 about 15' away from my Tempest. They track temperature and humidity very closely. Wind can change directions between buildings and trees. Sometimes one registers a bit more rain than the other.
Davis is a very good choice as well. AcuRite has a new model but for decades the 5-in-1 has been made of cheap UV sensitive plastic without update so I don't think much of the company.
   / Home weather station suggestions #137
Internet connection makes it easier to see how yours is reporting vs others nearby.
   / Home weather station suggestions #138
The main issue with the Ambient stations and other brands like it is that they put all of the instruments on one unit, which means it is impractical to mount the anemometer at 10 meters AGL where it belongs, which means your heat index, wind chill, and wind speed/direction readings are all going to be inaccurate.
The reason I like the Davis VP2 stations so much:
- Can remotely mount the anemometer
- Can add lots of different sensors for UV, soil moisture, etc
- Updates every 3 seconds or less, which is critical in a severe thunderstorm where you want to capture max wind gust
- Uses solar/capacitor design so that battery replacements are several years between
- Has option for 24 hour FARS to keep temperatures accurate in summer
- Rainfall tipping spoon can be calibrated to match manual gauge readings almost perfectly
- Radio transmission range is WAY greater than most other stations, opens more mounting location options
   / Home weather station suggestions #140
I've been using Davis wireless, solar powered weather equipment for more than 30 years. Needed a few minor replacement parts now and then but mostly bulletproof.
I have mine mounted on a hilltop, over 1/4 mile from the house. There is almost no limit to the allowable distance between sensor and display using the appropriate number of repeaters.
2004 Kubota R520 S (A57148)
2004 Kubota R520 S...
Indy Power Wrench (A57454)
Indy Power Wrench...
John Deere HPXD (A57149)
John Deere HPXD...
2016 SHADOW CRUISER (A58214)
2016 SHADOW...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
Giyi Horizontal Log Splitter (A57149)
Giyi Horizontal...
