Home Made Trailer
/ Home Made Trailer #21
Do you have a clearer picture of your stickers? Where did you have them made up? How did you make your Texas stars?
/ Home Made Trailer #22
wow did I see a rease hitch on the back of that? can you pull a trailer with a trailer out there?
/ Home Made Trailer #23
</font><font color="blue" class="small">( I preassembled the wiring harness and laid it in after painting. The connections are sealed with a heavy wall heat shrink that utilizes a heat melt glue to keep the moister out.
)</font>
I used to have a bunch of that stuff when I worked for an electronics Company and did wiring harnesses all the time.
It comes in handy
/ Home Made Trailer #24
That is one awesome piece of work. Probably the nicest trailer I have ever seen. I have one question though, Can you actually load it up to 10,400 lb and be within all the specs for the coupler, ball, draw bar, receiver hitch, etc? I have seen tongue pull trailers with two 7k axles but I have never seen a complete hitch system rated for over 10k.
/ Home Made Trailer #25
Gary I rate that trailer right up there with Harv's work. Very nice work indeed.
Seems kind of a shame to leave such a nice trailer out in the elements now that it's finished.
How did you prep the steel prior to paint?
/ Home Made Trailer #27
Gary,
You did a first class job on that trailer. Really nice!!
Did you keep track of your costs? I've always been told that you can't build a trailer for what it costs to buy one from somebody who builds them every day. Their price for materials is so much cheaper from buying in bulk.
I have a high end 16 foot trailer that I paid $900 for from a dealer. I have no labor into it, but I've always been curious about actual costs.
Thanks,
Eddie
/ Home Made Trailer #28
</font><font color="blue" class="small">( This is the rear wiring breakout. All the connections are soldered and the heat shrink has a heat activated glue that seals out the moister.
)</font>==
Did you put a 3rd. center mount brake light on it?
/ Home Made Trailer #29
very nice. i know you saved a bundle on that. that level of quality would have run the price up quite a bit. great job.
/ Home Made Trailer
I kept a complete cost log just for the fun of it. I also pre-calculated the weight which came in around 2400lb. The cost was around $2500 but I purchased most of the steel before it started going up like crazy. You can’t really save much money building your own trailer, but I couldn’t buy one like I wanted. That’s pretty much how it is with most of my projects. I have to build one to get it like I want it.
In Texas, you can legally pull multiple trailers. The restriction is on overall length which I think is 65 feet. To safely pull multiple trailers, you need not just a hitch receiver, but a wiring jack and hookups for your safety chains.
There is no 3rd center brake light, just the triple clearance which is required for trailers over 80 inches wide.
To pull a 10k hitch trailer, you need a truck, bumper/hitch receiver, drawbar, ball, trailer tongue coupler, safety chains, trailer frame and trailer axles rated for 10k. Amazing how most folks don’t think about this. I have a Ranch Hand rear bumper rated for 10,000lb (non-weight distributed) that is both bolted and welded onto my 3/4ton truck frame. There are a couple of hitch receivers on the market that are rated for 10,000lb. My drawbar is made from a SOLID piece of 2 inch square bar and has a 10,000lb rating stamped into it. I use a 2 5/16 ball/coupler that are rated for 12,000lb.
I made this trailer for myself and if I sold them, I’d have to charge way too much because of the time it takes to do the little things right. So, this one will have to last me a lifetime.
The Texas Stars are cast iron and come from King Architectural metal supply. They are on the web and sell mail order. The cast iron is “grey cast” which is a weldable metal just like all the ornamental castings these days. They were something like $3 apiece. If you aren’t a Texas Star buff, you can use this technique with other castings. There are many to choose from.
Attached is clear picture of the warning and danger stickers I had made at a local print shop.
I hope this answers all the questions. Thanks for the kind comments.
/ Home Made Trailer #31
Gary,
Just one word for that trailer...SWEET!
/ Home Made Trailer
PineRidge,
I forgot to answer your question regarding preparation prior to painting. I don't have any pictures of me sandblasting it, but I do have some pics of me sandblasting a gate entry I built for a friend. I'll get around to posting that project some day.
The sandblaster is a Schmidt driven by an Ingersol-Rand rotary screw compressor that delivers 100CFM at 100PSI. I use a Bullard air fed helmet and matching filter to provide grade D breathable air.
/ Home Made Trailer #33
very nice trailer and great workmanship too.
your right about the cost, can't build one cheaper than you can buy one with the higher cost of steel.
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
3 Point Trailer Mover (A65640)
3 Point Trailer...
Wood Fence Post (A62613)
Wood Fence Post...
2008 Lincoln MKX SUV (A64557)
2008 Lincoln MKX...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
