Home made tools for V Mesh fence installation
   / Home made tools for V Mesh fence installation
This is the way it works.
Think itty bitty bites.
By using this tool or something that performs the same function you crimp the horizontal wires removing slack.
When the section is "dressed" as we call the crimping process it will be just as tight as the bottom strands.
The fence will look fantastic. And if you have such a tool in your tool box you can repair fence that's been deformed by horses rubbing or pawing against the fabric.
It goes from this.
   / Home made tools for V Mesh fence installation #35
Excellent post, carefully thought out and images are good... should be very helpful.
   / Home made tools for V Mesh fence installation #36
   / Home made tools for V Mesh fence installation #37
</font><font color="blue" class="small">( I only use steel fence ties. )</font>
Harvey, I didn't even know they made those. They sure would have made life a lot easier on my fence. Can you get them a the fence supply store? I bought a roll of heavy guage galvanized wire and cut out my own.
Thanks for the information.
James
   / Home made tools for V Mesh fence installation #38
James
   / Home made tools for V Mesh fence installation #39
Neat tool. I hadn't thought of that approach. I saw a commercial one, very old, that was a pliers type, 2 prongs on one side, three on the other, one squeeze and you had two "v" crimps. Saw an old farmer use it to tighten a fence that began almost laying on the ground. He just walked down it, squeeze, squeeze, squeeze and at the end had a tight fence.
I tried to find one, no luck even having the local grange research their catalogs. Finally built my own using a Vice Grips with angle irong welded to the jaws. Works great and only one hand. My mistake was clamping the two angle irons in the grips then welding. I should have put two pieces of wire between the angles first to get a more parallel fit on the fence. End result is like field fence with the "V" tension crimps.
Sorry, no pics, no camera.
Harry K
   / Home made tools for V Mesh fence installation #40
Harry K
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
