Home made starting system.
   / Home made starting system. #2
Unless the dozer pto was designed to run the opposite way isn’t this going to start it backwards?
From the comments???
"Main gearbox neutral . Direction transmission In reverse."
This morning I can get my brain spinning in either direction. :)
   / Home made starting system. #4
This idea never crossed my mind but then I do have batteries. :)
I did in the seventies with 2 MF tractors. The dead tractor had ground speed pto. The dead tractor had 1 rear wheel jacked up and ground speed pto was selected. With it in reverse, the clutch pedal was raised. It started straight away.
10-16.5 SKS9 Tires (set 4) (A47809)
10-16.5 SKS9 Tires...
Kubota Sweeper Broom (A47809)
Kubota Sweeper...
WORK BENCH (A47001)
WORK BENCH (A47001)
2018 KENWORTH T680 SLEEPER (A45676)
2018 KENWORTH T680...
John Deere MX5 Brush Hog (A47809)
John Deere MX5...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
