home made sprayer???
/ home made sprayer??? #1
Pirwin21
NW Pennsylvania
2007 Kubota L3400 HST
I recently adopted 2, 35 gallon water tanks. I would love to turn one of these into a pressurized sprayer. Is this even a remote possibility? And if it is, is it practical? Or am I better off buying one. Thanks for the insight.
/ home made sprayer??? #2
If the only part you have so far is a tank or tanks, you probably can buy a completed unit for about same as all the parts.
A question for you, are you expecting to pressurize the tank like a hand held sprayer? If so how will you do that?
I was intending to use it to water a garden and was planning on putting the tank in the back of my rhino to transport it...
/ home made sprayer??? #4
For an actual sprayer, you can usually buy one for what you’ll spend to build one. But, if you just want it to water your garden, you could buy a $15 bilge pump and some hose and it should work for you. Mount the bilge as close to the bottom of the tank as you can. It won’t have a lot of pressure, but you shouldn’t need much.
/ home made sprayer??? #5
I just built one this spring for my buddy who runs a mowing company. We made it out of a 30 gallon barrel. We had $40 in hose and fittings, $59 in a 2.4 gpm pump, and the rest of what we needed we had. We used 2 old mower wheels and a old bed frame to make the chassis. It has a 12' side spray pattern and will spray 1 acre per tank with the mix he uses. I welded it all up for him for $50. Works great but like the others said if you did not have a lot of the stuff laying around you could just by one cheaper.
Chris
/ home made sprayer??? #6
The pump is probably going to be the most expensive part. If you have a pump or if you can find one cheap, it might be worth the effort.
/ home made sprayer??? #7
If you want a decent sprayer you can build one for a lot less money and have what you need the most. We used whatever we had on hand and only purchased what we didn't.
Here is a sprayer that we built a few years back. We even made the foam marker for it.
I say if you are handy with tools "go for it"
/ home made sprayer??? #8
I just re-built a sprayer last night to spray roundup on the old pasture in preparation for putting in a community garden. (I'm not too late for a garden yet since we just had frost again this morning.) I had bought a sprayer off a guy earlier this spring, but it wasn't in great shape. The hose was only about 4 feet long, the spray gun looks like it was left over the winter and split from freezing, and the pump wasn't wired to anything.
I hooked an old air hose (brass fittings) to the barbed fitting coming off the pump. I used a ball valve and an old nozzle from I-don't-know-what on the end of the hose to be a spray gun, and I wired the pump to some alligator clips from a broken battery charger so I could hook it to a spare battery. I put it all in my dump cart and set out to wreak death and destruction on all unwanted vegetation.
Total build time = 15 minutes. Total cost = $40 to the guy for the broken sprayer (he threw in an extra pump too). Everything else was stuff I should have thrown away years ago, but I just knew that I'd use it someday. If I'd had to buy all the parts new, it would have been cheaper to just go buy a ready-made sprayer.
My wife says there'll be no living with me now that I finally found a use for a hundredth of a percent of the junk that I probably should have thrown away.
/ home made sprayer??? #9
If you are just going to water,why do you need a pump.I use a 55 gal.drum and a gravity system on the rhino.$20.00 worth of plastic pipe and a free drum.I am going to build a similar set-up for round-up with a pump.
2015 Ford Transit Connect Van, VIN # NM0LS7E74F1193985 (A65563)
2015 Ford Transit...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
