Home made sawbench
   / Home made sawbench #1
njc110381
Gloucestershire, UK
Kubota B4200
Hey guys. I'm quite keen to make a few implements for my tractor but don't really know where to start. I need a loader but I think that's perhaps a bit complicated, so I'm thinking of making a saw bench. Has anyone done this? I know the old models with the free blade sticking up through a table were pretty dodgy but the modern ones look very good. I have a friend who uses one on his MB Trac and it really flies through whatever you feed it.
The only thing I'm a bit stuck on is the gearbox and the 90 degree turn that the power has to make so as the logs can fall to the side of the tractor. If I make it in line then the seat will get in the way of the longer logs.
I tried to search but "saw" is too short for the search facility so I didn't come up with much.
   / Home made sawbench #2
That's the kind of thing I want. It's hard work using a chainsaw and they're smelly horrible things that drink fuel and spray oil everywhere! I can't believe quite how much the bench saws cost, although looking at the seperate parts I'm not sure I will make much of a saving by the time it's done.
I have been tempted to buy an old one and modify some guards onto it, that could work out cheaper.
   / Home made sawbench #4
If your buying one! buy a good one even if it costs more, it usually saves in the long run
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2382 (A60432)
2382 (A60432)
2014 Bobcat T550 (A59228)
2014 Bobcat T550...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
1766 (A60430)
1766 (A60430)
