home made rowcrop tractor
/ home made rowcrop tractor #1
simplicityguy92
im building a mini row crop tractor sorta like the ones on www. vintage progects .com ( soon to post pictures)
and i was wondering if andbody could tell me how to build a transmission
iwas think of haveing a lever activated belt tensinor then to change geears i just losen it then move the belt to a differant pulley on a step pulley
then tighten t the belt
if anybody has any sugestions please tell me
/ home made rowcrop tractor #2
I built a tractor and just used a Wheel Horse tranny....makes backing up a LOT easier.
Unless you mean a two wheeler.....
I have a Midland you can have for $50...need the room.
i have a small tractor for work,
im just building the mini rowcrop for show and it will be small enough that i can put in neutral or disengage the belt and pull it backwards
i just want to no a good way to change gears so the trany would just be for forward geers
/ home made rowcrop tractor #4
Gotta....got a lawn tractor tranny you can have too.
Just went out and looked at that tranny.....s'heavy! Shipping would be a bear.
Thing is...you're gonna have to step the speed way down from the engine to the axle.Can be done with pulleys and belts,but there are easier and cheaper ways.Maybe a gear box from a tiller? Sure,you will get a primary speed change from the step pulleys but that's still gonna be way too fast for the final drive.What's a go kart use...10-12 on the engine and 60-72 teeth on the axle? Plus,the tires are going to be much larger than a cart meaning the axle speed will have to be lower still. See what I'm getting at?
/ home made rowcrop tractor #5
I got to agree with Bob on this one. There are a lot of lawn tractor transaxles for sale on e-bay for less that 100$ that have a 5 or 6 speed trans axle with reverse and the gear reduction is already done. I go to the Southeast Old Time Threashers Reunion in Denton NC every year and there are a lot of mini's built to look nearly like the origional production row crop tractors of yesterday and a lot of them have lawn tractor rear transaxles for starting points. Here are some that are on e-bay now.
transaxle, Parts Accessories, Riding Mowers items on eBay.com
HTH's later, Nat
i already thought of lawn tractor transmison
i just wanted to see if anybody had any other suggestions
i plan to make a scaled downe replica hay wagon or mabe a manure spreader
to go with the mini tractor
the tractor is based on plans from vintageprogects.com
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
2011 WESTERNSTAR 4900 (A65643)
2011 WESTERNSTAR...
