Home-made puncture 'slime'.
/ Home-made puncture 'slime'. #1
alchemysa
Veteran Member
South Australia
Kubota B1550HSD
Working around a demolished corrugated iron shack, and ripping out some nasty box thorns, I've been particularly concerned about punctures from nails and thorns in the tyres of the tractor and ride-on mower. So you may be interested in my home-made puncture goo. My first attempt was made using a thin mixture of water and 'rubberised' tiling cement. A very 'thin' half pint of this in each tyre worked very well, but I discovered the left-over mixture 'set' in the storage bottle after a month so i guess the stuff in the tyres might do the same thing . (No problem really - if it does it will just roll around and form little marbles). My next step was to find something that was finely powdered, non soluble, and slightly flexible, that wouldnt 'set' in the tyre. Powdered rubber would be an ideal base but I couldnt think of where to get it. But I found a place that had powdered plastic that they use to 'plasticoat' wire-ware, and that has so far proven successful. I bought a couple of pounds of plastic for $5, which is probably enough for a couple of dozen tyres if I use a handful of plastic in each tyre. So all this puncture goo is then, is a mixture of powdered plastic and water. Ultimately the amount of water in the mixture is not important, its really just there to splash the plastic around inside the tyre and get it to the puncture hole. Water and plastic don't 'mix' so to create a slightly thicker slurry that was easier to pump in I added a little bit of 'No More Gaps' water based acrylic gap filler to the mixture. This might also provide a bit of (probably unneccessary) extra adhesion in the puncture hole.
The principle is simple enough. In a revolving tyre, the water washes the powdered plastic toward the puncture. Escaping air pressure then jams the plastic deep into the hole. The larger particles bridge the hole first, then the smaller ones get jammed in behind to fully seal the hole. In practice this whole process takes about a second or two. It will plug some pretty big holes too. If you dont pump it in at a nice slow speed it will plug the valve stem quick smart even though the plastic is almost as fine as table salt. (Its easily cleared again with water). I used an old hand operated oil suction pump to put it into the tyres but theres probably a few better ways of doing it. In fact the dry powder can probably be pumped or blown directly into the tyre, and the water added later. So far it seems to be working nicely. I havent noticed any new punctures, and it plugged a particularly large and difficult one that I couldn't mend with puncture plugs alone. In theory it should even work in sidewall punctures too as I imagine that, in a slowly revolving tyre, water is continually running down the inside walls of the tyre.
/ Home-made puncture 'slime'. #2
That sounds like a good idea, however with little kids and to many projects as it is, I think I would buy the green slime from the local superstore. Do they have Slime in your neck of the woods/planet.
Yep, but its $35 a litre and I figured I'd need about 4 litres for all the tyres I have to worry about.
/ Home-made puncture 'slime'. #5
Not to sure I would use that home brew. What is it going to do to your rims over time? Corrosion or rust. It will freeze in the winter. Will it react with the rubber over time and destroy the rubber?
$35 for a litre is a rip off that's for sure. I sell Texas Refinery Corp.'s tire seal here in the US and it only cost $103.20(US) for a 6 gallon bucket. That's 22.7 litres at a cost of $4.54(US) per litre, delivered. At the current converssion rate $35 Austrailian dollars is about $27.0789 USD. That would be $614.69 Australian dollars for a 6 US gallon bucket at his price. :eek: Sounds like someone has a nice scam going to me.
DieselPower. I would happily pay the prices you quoted. The local autoparts shop quoted me $33 plus GST (10% TAX) for the bottle they had. It might have been a little bigger than a litre, but not much. I also looked in a local discount auto parts chain but they didnt have it. They had aerosol puncture repair stuff but I've tried that before and IMO its pretty useless. Freezing is not a risk here. (I'm 52 and I've never even seen snow). Corrosion might be, but the Kubota Operators manual approves water in the tyres for weight. (Real 'slime' is water based anyway). Theres nothing in my 'slime' that will damage the rubber. But I'll look around and see if the the Texas Refinery Tire Seal is available over here.
/ Home-made puncture 'slime'. #7
I can give the home office a call if you like and find if there are any distributors in the Adelaide Australia area. They have plants in Ft. Worth, Texas, Toronto and Moose Jaw, Sask. Canada, Mexico, D.F. and in Echternach, Luxembourg. They have a worldwide distribution network set up around each plant. I'll post a reply with their answer tomorrow.
A note on those aerosol can "Fix-A-Flat" type emergency tire repair products. If they are left in a tire they can dry out like concrete or glue. I have had to dismount alot of tires over the years that had that junk in them and some had the tires so stuck on the rims I had to cut the tires off with a knife.
/ Home-made puncture 'slime'. #8
Just did a little bit of quick internet searching and think I found some retailers in Australia. One is Air Seal's Tyre Milk and the other company is Pride Mobility. I'll still check to see if there are any TRC dealers there for you but this is a starting point.
/ Home-made puncture 'slime'. #9
Try various coarseness of ground pepper. Works well on radiators.
Larry
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
HYDRAULIC CATTLE SQUEEZE CHUTE (A60736)
HYDRAULIC CATTLE...
2007 Acura TSX Sedan (A61569)
2007 Acura TSX...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
