Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
I want to show how I made two corps plow with old and slightly different horse plows.
I checked the winter, two days after the minor frosts. The ground is wet and not polished blades, which adhere to the land.
Brushed snow on the second day of Christmas.
Progress Report for two years
   / Home-made mini tractor 4*4 with the joint joined frame #158
Very nice. I like the tall seat back.
   / Home-made mini tractor 4*4 with the joint joined frame #160
Definitely one of the better tractor builds Vladimir. Congratulations.
Back home, plows have fallen out of favor because they don't perform well in rocky ground. I am no plow expert, but if your mouldboards are rusty, could you buff them with a wire wheel? I recall a neighbour back home that greased his moldboards after fall plowing to prevent the heavy clay soil from sticking. One other thing, does anyone over there use a coulter? Counters are vertical discs set up to slice the sod before the share comes along to cut the sod off, and the mouldboard turns it over.
I don't want to take anything away from a brilliant build, but I am curious....
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
HAY SPREADER (A58214)
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
