Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
I want to show how I made two corps plow with old and slightly different horse plows.
I checked the winter, two days after the minor frosts. The ground is wet and not polished blades, which adhere to the land.
Brushed snow on the second day of Christmas.
Progress Report for two years
   / Home-made mini tractor 4*4 with the joint joined frame #158
Very nice. I like the tall seat back.
   / Home-made mini tractor 4*4 with the joint joined frame #160
Definitely one of the better tractor builds Vladimir. Congratulations.
Back home, plows have fallen out of favor because they don't perform well in rocky ground. I am no plow expert, but if your mouldboards are rusty, could you buff them with a wire wheel? I recall a neighbour back home that greased his moldboards after fall plowing to prevent the heavy clay soil from sticking. One other thing, does anyone over there use a coulter? Counters are vertical discs set up to slice the sod before the share comes along to cut the sod off, and the mouldboard turns it over.
I don't want to take anything away from a brilliant build, but I am curious....
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2012 International Derrick Digger (A55973)
2012 International...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
