Home made Log splitter issue?
   / Home made Log splitter issue? #1
mac230305
Aebi TT75
Hi
Live in Italy so using European spec's
Need some help,
designed my own log splitter which is based on 16cm (6") I-beam (see photo) it has a 13t ram but due to control value by-pass set (125 bar)is putting out only 8t, but is working fine on 99% on the logs. my issue is the beam is getting damage on the leading edge of the beam
any ideas! is the beam "twisting"? I was planning to up the by-pass pressure but have put that on hold due to this .
thanks Paul
   / Home made Log splitter issue? #2
First and foremost the pics aren't working.
Secondly what is the spec on your beam, besides 6"? How thick is the web and the faces? How long is the stroke? How high off the beam is the cylinder mounted? How tall is the pusher and the wedge?
Sounds to me like the beam is too light. What style wedge do you have? What type of wood are you splitting? What pressure are you building and what is the relief set to?
Report back :)
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Freighliner Tender Truck (A56438)
Freighliner Tender...
Cat CB24B (A60462)
Cat CB24B (A60462)
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
