Worlds Most Sophisticated Home Made Log Splitter?
   / Worlds Most Sophisticated Home Made Log Splitter? #11
I’ve got a catch table on mine and it’s a huge work saver. I’d recommend re locating the switch on the end to somewhere safer.
The safety people will be out of sorts if I move the switch. lol I thought about putting it on a hinge, or even trailer plug, so I could remove it for large rounds. But the table idea will require a total rethink.
Yes, backwards is Momentary (Jog) and Return latches it to return to either the 1-5 preset or all the way back. The Joystick always takes priority, no matter what the thing is doing. Like I said, I didn't realize how much I would like the preset. I have three different size stoves on the place and a large fireplace, so all of my firewood is of varying sizes.
So far, the thing seems to have unlimited power for the ELM rounds I have put through it. Since no hearing protection is required, I'm guessing, I would hear something, either the motor or a relief making a different sound if it stalled. I imagine, that the really knarly stuff, I would do manually anyway.
   / Worlds Most Sophisticated Home Made Log Splitter? #13
If you grow bored of a mere overly sophisticated log splitter and want to build an overly sophisticated wood processor, check out this build for inspiration. With a few boxes of surplus industrial control components, this thing could be a robot. It could run all by itself and shoot you a text message to let you know that it's done with the pile you tasked it to cut.
If I can point it at a tree and have it call me when it has the splits stacked next to my stove and I can buy it for under a Grand, I'm all ears.
   / Worlds Most Sophisticated Home Made Log Splitter? #14
If we’re talking about mythical contraptions I’d rather just have a house that maintains its own temperature without a utility bill.
Once you have the electrical hydraulic valves, the possibilies are endless. I was even thinking mind control. But I never managed to levitate the rounds onto the splitter.
   / Worlds Most Sophisticated Home Made Log Splitter? #16
But I bet you have more than $1000 in this build and not even close to being able to cut and split and stack a tree by itself.
   / Worlds Most Sophisticated Home Made Log Splitter? #17
Great job!
Any videos of this thing running? Would be sweet to see it running.
   / Worlds Most Sophisticated Home Made Log Splitter? #18
Nice build...:thumbsup:
If you wanted to you could add a microprocessor and switch out the current relay board with a similar one that interfaced via serial bus or USB even...install one of the mini Linux kernels and it could be run with voice commands from a cell phone or other device...automated operations would only need a looped shell script...
FWIW...an eight channel 10A relay board with either a serial or parallel port interface is about $50...
Actually, it didn't cost much at all. The D05 Valve on sale at Princess Auto was probably the worst. I have some amazing friends.
As for the time spent, that's another discussion.
And, a video? It's kind of like a woodsplitter going back and forth. lol Not really much to see here folks!
I just like it because it's everything I always wanted in a splitter that others lacked and it actually got built and most importantly, got FINISHED!
   / Worlds Most Sophisticated Home Made Log Splitter? #20
Not really all that mythical, but I don't think I'd like living in a cave or an old Missile Silo.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
Mobile toilet (A55758)
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRK (A51406)
2008 INTERNATIONAL...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
