Home Made Landscape Rake
/ Home Made Landscape Rake
There was too much play in the pivot so I welded a 1" steel pipe sleeve in the box beam. Works great.
This was this morning on the farm in North Jersey. Ain't Spring great! /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
/ Home Made Landscape Rake #23
Looks very similar to what it looks like here in SE PA! The poor daffodils are questioning why they bothered to bloom...
/ Home Made Landscape Rake #24
Just curious. I have been wanting to build one of these also....but I am stuck on what I am going to do about the rakes teeth. What have you got in mind to use for this?
Bob /forums/images/graemlins/cool.gif
Oops...sorry about the stupid question. I see you bought them. Probably what I will have to do. Right now I am building a front end scoop for my X475 then I will start on an aereator.
Bob
/ Home Made Landscape Rake #25
For your drilling problem try the Mcmaster Carr catalog page 2260 for step drills. We use them regularly and have had good luck with them.
Don't forget to post your projects when they start. I would have never attempted to make a rake or anything if I didn't have the inspiration from others making their own stuff. This is an invaluable web site.
Great. I've seen these but didn't have any experience with them. Thank you. I'm trying to figure out a way to scam a drill press out of my wife. We have some big projects coming up this summer, so I'll try to sneak a press into one of the those projects.
"Oh look honey, they sent a drill press to our house accidentally" /forums/images/graemlins/cool.gif
I'm done! Well, except for some wheels, a kick stand and any comments/advise that comes from you guys. I tried it last night and it worked great. Can't wait to really use it.
I think I will add a bracket on the underside of the box beam for extra support when there is increase stress in the rake. I will bolt the bracket on because it will have to be removed if I want to spin the rake around 180 degrees.
/ Home Made Landscape Rake #32
Under which box beam? I can't see where you would need additional support as you have the braces on top. Maybe an angle from the left or right side (or both) where the hitch pins are connected to the arms and then back towards the pivot point, but that is the only "weak" spot I see. I will be curious if the single bolts holding the tines in place will work if you use this rake backwards. Not doubting, but I would have some concern as to how they will hold up.
Great job, and it looks like you have finished a great project. Thanks for the pics.
/ Home Made Landscape Rake #33
Your project looks great!
With the single bolt, what will keep the tines from rotating? I'm assuming the tines have a flat edge that is up tight against the angle iron.
/ Home Made Landscape Rake #34
</font><font color="blue" class="small">( With the single bolt, what will keep the tines from rotating? I'm assuming the tines have a flat edge that is up tight against the angle iron. )</font>
I have been thinking the same thing. He could weld on some spacers inbetween the tines on the underside of that angle iron and then they could not move.
/ Home Made Landscape Rake #35
Nice Job on the rake. I did almost the same thing, but I used the tines that have 2 holes in each one - I had to drill alot more holes /forums/images/graemlins/tongue.gif but it looks like it will work great. Had the kids put all the bolts in for me /forums/images/graemlins/cool.gif. I didn't make all the front end stuff, I used my back blade as a guide and intend to take the blade off and substitute the rake in place of it. Might not be ideal, but it takes up less space and took less work to make.
I really wanted to get the tines with 2 bolts but was put off at the thought of drilling that many holes. They were actually the same price. I cut 1" spaces that I have to weld onto the bottom. I was just too excited to try it out. None of them twisted though when I dragged it around last night. But I'm sure with enough force they will.
I was thinking of having kids for the sole purpose of having free labor /forums/images/graemlins/wink.gif.
<font color="blue"> Under which box beam? I can't see where you would need additional support as you have the braces on top. </font>
Look at the image attached. Where the arrow is pointing to. It would take off stress at the pivot point if it wanted to flex.
/ Home Made Landscape Rake #38
The brace you are thinking of adding would be important for a blade to help with the shock loads. With flexable tines it is not so important, but would help. (Are you thinking of making a blade for it too? you have a gteat 3-point frame for it.)
It will not be handy if you need to unbolt it all the time. Could you cut 2 welds, & add an inch spacer between the plate & the main angle iron? Then the bracket would not be in the way.
I forgot to look at the pics closely - did you put a grease zerk in to the pivot to grease it every so often?
--->Paul
Man, I didn't even think of that. I could build a blade for it. Thanks for the suggestion. I will also put a grease zerk on the pivot.
Thank you again.
/ Home Made Landscape Rake #40
How about guage wheels to....Good job, Im thinking about doing the same thing.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2026 GIYI FB77 Feller Buncher Skid Steer Attachment (A66734)
2026 GIYI FB77...
2012 Mitsubishi Fuso FEC72S Box Truck (A66736)
2012 Mitsubishi...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
