Home made EZ weights.
/ Home made EZ weights. #1
Hollywood
Southwest Georgia
John Deere 670 and John Deere 140
Here are some pictures of my "knock off" ez weights system. I used 1/4" plate for the base and 1" all-thread for the bar. I bought the plate locally and it had been cut into rough circles with a plasma cutter, but I trued them up on a rather large lathe.
I used a Bridgeport mill to do the bolt pattern. 1/2" carriage bolts were used to attach them to the wheel. I welded the 1" nut to the plate, but only tacked the all-thread in place in case I need to replace it in the future.
Here they are mounted and awaiting some 25 lbs. plates.
Another view mounted.
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
KL480 Ventrac tiller
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
