Home Made debris forks
   / Home Made debris forks
That's a real smart design that uses that lip on your bucket, props dude!
I'm liking that design. I want something fast to slip on/off for brush pile type stuff. Also thinking about a bucket modification to allow me to push/move larger quantities of snow. Even as I hope for not too much snow.
   / Home Made debris forks #12
I also DIY'd a set of 'clamp on forks'.
BUT
I also made a dedicated pallet that fits my forks 'just right' which comes real handy very often.
I also treated it with wood preservative since it has to live outdoors.
Since we often collect fallen branches the 'pallet' keeps them from dropping out.
I also find it handy when I want to move cut firewood as it sure extends the bucket capacity and saves trips.
   / Home Made debris forks #13
Buggs67,
Here's my homemade brush forks I built about 10 years ago along with a jib boom, and a set of bucket teeth.
I used 1/8" x 1" x 2" tubing for the forks, and 3/4" plywood for the platform.
The brush forks are used every spring/summer, and are fastened with 3- 1/4" x 20 grade 8 bolts thru each side of the bucket.
The hinged plywood platform is attached to the top of the brush forks with 2- 1/4" x 20 eye bolts drilled and tapped thru the top of the brush forks.
The vertical wooden headache rack is also attached with 2- 1/4" x 20 eye bolts drilled and tapped thru the top edge of the bucket.
When I want the wooden platform up, I just use a bungee strap to hold it in position.
Hope this gives you more information to help you with your final decision.
KC
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2007 TRANSCRAFT 48X102 FLATBED (A52472)
2007 TRANSCRAFT...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2004 INTERNATIONAL 9900I (A52472)
2004 INTERNATIONAL...
