home made bucket forks
   / home made bucket forks #1
gerard
Syracuse NY
Kubota L2500DT w/FEL
Here's a set of clamp on forks I made in about 45 minutes with some scrap stock I had laying around. Not real heavy dutys but well enough for carrying long objects, trees' fenceposts and the like.
closeup
   / home made bucket forks #3
hey I see you have one of those L2500's too.
How much weight have to put on the forks so far?
Lets see, I weigh 180 and can do dips from the very end of them without a problem. I piled on 8 horse standards the other day, they weigh about 40lbs each. The square tube was thick walled (3/16" walls) so they're a little stronger than they look.
   / home made bucket forks #5
Looks good. I like the way you have them clamp on. Quick, and easy.
   / home made bucket forks #6
Gerard, I'll take a set for me and keep a set in reserve for GolfGar4. /w3tcompact/icons/smile.gif Please make mine NH blue and GolfGars should be one each NH blue, Kubota orange, and throw in an extra one John Deere green (cuz ya never know) /w3tcompact/icons/grin.gif
How soon can you have them to me? /w3tcompact/icons/laugh.gif
   / home made bucket forks #7
OK gerard, seriously, can you give me a few dimensions and material sizes so I can duplicate your masterpiece.
Remember, imitation is the most sincere form of flattery /w3tcompact/icons/blush.gif
I used 1 1/2 inch thick wall square tube for everything. The thick wall is 3/16" thick vs 1/8 for "normal" tube. I only used this because I had a 10 foot piece laying around so my dimensions were kind of dictated by what I could do with 10 feet! I just drilled a 1/2" hole through the top peice, welded a nut to it, used some all thread and welded the handle to that and whalla! (The 1 1/2 " just happened to be the perfect size to slip over the bolt on tooth bar. Sometimes you just get lucky!!! /w3tcompact/icons/smile.gif).
   / home made bucket forks #9
Cool /w3tcompact/icons/cool.gif
Thanks
   / home made bucket forks #10
Also how long is the spacer that is between the upper and the lower tube? This is out on the edge of the bucket?
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
1272 (A50490)
1272 (A50490)
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
Flatbed Body for Heavy Truck (A50854)
Flatbed Body for...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
