home made bucket forks
   / home made bucket forks #1
gerard
Syracuse NY
Kubota L2500DT w/FEL
Here's a set of clamp on forks I made in about 45 minutes with some scrap stock I had laying around. Not real heavy dutys but well enough for carrying long objects, trees' fenceposts and the like.
closeup
   / home made bucket forks #3
hey I see you have one of those L2500's too.
How much weight have to put on the forks so far?
Lets see, I weigh 180 and can do dips from the very end of them without a problem. I piled on 8 horse standards the other day, they weigh about 40lbs each. The square tube was thick walled (3/16" walls) so they're a little stronger than they look.
   / home made bucket forks #5
Looks good. I like the way you have them clamp on. Quick, and easy.
   / home made bucket forks #6
Gerard, I'll take a set for me and keep a set in reserve for GolfGar4. /w3tcompact/icons/smile.gif Please make mine NH blue and GolfGars should be one each NH blue, Kubota orange, and throw in an extra one John Deere green (cuz ya never know) /w3tcompact/icons/grin.gif
How soon can you have them to me? /w3tcompact/icons/laugh.gif
   / home made bucket forks #7
OK gerard, seriously, can you give me a few dimensions and material sizes so I can duplicate your masterpiece.
Remember, imitation is the most sincere form of flattery /w3tcompact/icons/blush.gif
I used 1 1/2 inch thick wall square tube for everything. The thick wall is 3/16" thick vs 1/8 for "normal" tube. I only used this because I had a 10 foot piece laying around so my dimensions were kind of dictated by what I could do with 10 feet! I just drilled a 1/2" hole through the top peice, welded a nut to it, used some all thread and welded the handle to that and whalla! (The 1 1/2 " just happened to be the perfect size to slip over the bolt on tooth bar. Sometimes you just get lucky!!! /w3tcompact/icons/smile.gif).
   / home made bucket forks #9
Cool /w3tcompact/icons/cool.gif
Thanks
   / home made bucket forks #10
Also how long is the spacer that is between the upper and the lower tube? This is out on the edge of the bucket?
Bandit 150 Pull Behind Wood Chipper (A47384)
Bandit 150 Pull...
2018 Ford F-250 Extended Cab Reading Service Truck (A50323)
2018 Ford F-250...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
Caterpillar D6K Crawler Tractor Dozer (A50322)
Caterpillar D6K...
