Home heating fuel vs. #2 diesel
   / Home heating fuel vs. #2 diesel #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
My son in law is replacing his heating system in his house and has a hundred gallons or so of home heating fuel he needs to get rid of. The guy that fills his tank tested it for moisture and whatever and says it is clean and is the same exact thing as #2 diesel. I am considering pumping out the tank and setting up a couple of 55gal drums on my property. Would sure beat the 5gal at a time system I have now. I would weld up a support frame and maybe work a gravity feed system with filter, etc.
First question... is the claim the heating oil is same as #2 diesel true?
   / Home heating fuel vs. #2 diesel #2
Some people claim it is, other than taxes and dye. I think it also matters particular state regulations and phase in dates of sulphur reduction
The company providing says all their fuel is ULS (ultra low sulphur) and they seem very reputable but I have never dealt with them. Speaking of Wilco (Washington, Oregon based).
   / Home heating fuel vs. #2 diesel #4
Heavy equip mechanic here, also did fuel delivery. It comes outta the same pipe at the rack( terminal) , just won't be blended for cold weather.Pretty much everything is ulsd up here in the northeast now.
Thanks r8nger... that's what I wanted to hear. We don't need the cold weather blend here in the PNW.
   / Home heating fuel vs. #2 diesel #6
It's the same thing from my suppliers.
Chris
   / Home heating fuel vs. #2 diesel #7
I've been using HHO in my Kubota for a while now. I do treat it with 2 ounces of Power Service to every 5 gallon can. I'll double that if the temps are going to drop below 0F.
ac
   / Home heating fuel vs. #2 diesel #8
Not all states are using ULSD for heating oil yet, but it is heading that way.
   / Home heating fuel vs. #2 diesel #9
I switched my Kioti DK45 to HHO a couple of years ago. Last year when we replaced out oil furnace with a heat pump, I used the left over oil in my tractor. So far I have experience zero issues with HHO.
(6) Goodyear 8.25 R20 Tires (A51573)
(6) Goodyear 8.25...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
SHOULE PWD-10 LOT IDENTIFIER 120 (A53084)
SHOULE PWD-10 LOT...
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
