Home Depot DK2 Light Duty Trailers Any Good?
   / Home Depot DK2 Light Duty Trailers Any Good? #11
I have had the Home Depot version of this trailer for close to 10 years. We buy, remodel, and flip houses on the Oregon coast, about 75 miles away. I have never tried to stress it or overload it, but have hauled everything from Rock to cabinets in it with no problems.
The only thing that I don’t like is the 12 inch tires, I run them at highway speed often, and never had any problems, but the tread always wears a bit too soon. The end gate on mine pulls out similar to the stake sides on a truck. I replaced the original lights with led, and that worked out much better than the cheapies That it came with.
Well, yeah, for cotton balls you need something more like this:
   / Home Depot DK2 Light Duty Trailers Any Good? #13
"12 inch tires".
DANGEROUS when fully loaded, and highway speeds!
   / Home Depot DK2 Light Duty Trailers Any Good? #14
Balls....not bales LOL. The'd be a tad big for the end of a Q-Tip :)........Mike
"12 inch tires".
Just a thought on smaller tires would be that the surface speed at the point where the rubber meets the road is no more on a 12" tire than on, say, a 15" tire. Yes, the rubber and bearings would wear faster on the smaller diameter.
The "boat trailer tire" link below shows a load range D max load of 1220 lbs at 65 psi. A pair of these should handle a trailer rated at 2000 lbs. With that said, I would certainly be more comfortable with larger diameter tires.
Kenda Karrier S-Trail ST145/R12 Radial Tire w/ 12" Galvanized Spoke Wheel - 5 on 4-1/2 - LR D Kenda Tires and Wheels AM3122
   / Home Depot DK2 Light Duty Trailers Any Good? #16
I looked at these too, then opted to buy a 5 x 10 from Canada trailers. A bit more money, but a lot more trailer - 15 tires are a huge plus for me.
   / Home Depot DK2 Light Duty Trailers Any Good? #17
12 inch wheels are a whole lot better than the 8's that come on some trailers. I will admitt, I was nervous about the 12's on the uber cheap Harbor Freight 4x8. But it's been from Michigan to Georgia and back with 600-ish lbs on it, and has had probably 20k on it by now, typically hauling maybe 300-800 lbs, and mostly freeway, where the wife will loudly vocalize her displeasure with a trip taking any longer than necessary, which means often cruising in excess of 80 mph. After 7 years I replaced the tires due to cracking, but they were also getting quite worn down.
I wouldn't want to run them near capacity all the time. But they aren't the worst.
   / Home Depot DK2 Light Duty Trailers Any Good? #18
Hello,
I'm not sure how much money you want to spend, but have you thought about an aluminum utility trailer. I bought the 5.5'x10' aluminum utility trailer from Tractor Supply and really like it. I can move it around easily and it does have 15" wheels. Good luck.
MFWD
   / Home Depot DK2 Light Duty Trailers Any Good? #19
I'll second the recommendation of an aluminum frame trailer. I've had this 6.5x12 Aluma flatbed for 9 years, it still cleans up to almost brand new condition, and the only maintenance it requires is tires and wheel bearing grease. I paid around $1800 for it 9 years ago, and probably could sell it today for what I paid for it (similar trailers are going for about $2500 new now).
And yeah I know the rear end of the van is sagging in the photo below... that was 2 years ago, and since then the van has had suspension upgrades to compensate for the weight of the RV conversion, plus wheel and tire upgrades. In the photo I'm using a 5" rise draw bar, and now to tow the same trailer, I'm using a 0.5" rise draw bar...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
