MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 57,788
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I'm on my sixth year of wood burning as the primary source of heat in my house. And I'm on my 5th or 6th Holz Hausen. From experience, I can tell you, it DOES NOT dry the wood any faster, and in fact, it takes longer than single row stacks. Why? Because there is more free airflow around single row stacks. Plain and simple. So why do I use it?
- Its really fast to stack this way.
- I don't have to move the wood as far after I split it.
- I can fit about 6 cords of wood in an area of 78.5 square feet. Stacking 6 cords in traditional 4' high rows takes up at least 192 square feet and even more if you leave space between the 16" stacks, so way less than 1/2 the yard space for the same amount.
- Uses less tarps to cover.
- It looks nice! :laughing:
I find that the bottom layer of wood will be pressed into the dirt. However, I burn primarily locust, which is naturally rot resistant. So, in the spring, I just take that bottom layer, smack the logs together and toss it on the top of next winter's pile. It will be dry in a couple weeks just from the sun, and no worse for the wear.
I did have a problem last winter, and I'm pretty sure its not just Holz Hausen piles... the snow was so deep and blew so hard that it piled up three feet around my Holz Hausen. I did not realize just how deep the snow was until I started getting low on wood. By the time I realized that there was 3' of snow up against the bottom 3' of wood, it was too late. The snow had blown into the first two rows of wood all the way around and then melted and froze several times. The wood was basically a 10' ring of wood ice-cubes 32" thick by 3' tall!!! .... soaked and unusable. I had to dig out the center of my Holz Hausen to get to dry wood and ran out of wood just as winter ended. I will use that wood this year. And plan to tarp it better around the edges this winter.
