Holes in Bucket
   / Holes in Bucket #1
Trojans1965
North Alabama
John Deere 4410
I have a John Deere 4410 with a 300X loader. My bucket is 61" inside and it has SIX holes for a cutting edge or something. I cannot seem to find ANYTHING with SIX holes. They are spaced 1.5" 12" 12" 10" 12" 12" 1.5" for 61". ANY HELP Thanks
   / Holes in Bucket #2
One thing for sure with all them holes it won't hold
any water!:unsure:
Have you checked with EverythingAttachments.com
perhaps they can help with what ever you need
willy
   / Holes in Bucket #3
Weld the holes up and drill new ones to fit the new leading-edge holes.
   / Holes in Bucket #5
Six holes out on the cutting edge. I wouldn't worry about it. If you will be getting a hardened cutting edge or some type of tooth bar - just use any holes that match up or drill new ones. Those holes will not affect the form or function of the bucket.
   / Holes in Bucket #6
If you are ordering a toothbar several of the manufacturers will cut the bar to whatever hole pattern you have, IF you follow their measuring instructions precisely and give them good info.
So it's not a hindrance, it just means if you buy something that wasn't built to go on that bucket you'll have to add some of your own holes. It would have to be pretty swiss-cheesy before i worried about closing up any old holes. Whatever cutting edge you are bolting to it is giving all the real strength to that lip of the bucket anyway.
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2022 Case IH Steiger 470HD AFS Connect Quadtrac 4WD Tractor, (A50657)
2022 Case IH...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
