Hole Digger Solution
/ Hole Digger Solution #11
I'd agree with those who suggest a 40hp or so CUT for the 60ac based on versatility and experience. (Kubo 4200 :thumbsup:) IMO an L60 is a few sizes big, esp for the orchard.
Compare dual wheel and higher hp options for Ventrac. Low height and maneuverability may be a boon for orchard work. There are some awesome add-ons and support is pretty awesome.
Tractor has advantage of more used &/or local 3-PH & SSQA attachment availability. Attachments can be bought used and re-sold if they outlive their usefulness. Advantage tractor.
I suggest getting the right machine for the long haul. The post/planting hole part ought to be easy either way.
/ Hole Digger Solution #12
I hear you. I'm starting to think that no matter what i am going to have to have two machines. Thanks!
You need to be around a skid steer awhile they tear everything, one with wheels is pretty helpless in the dirt but one with tracks is great neither one can work good on a side hill. they are fast but thats it, they have no reach with a bucket. plus they are dangerous my neighbor was killed getting out of one with the bucket in the air and a hose blew and it pinned him and he bled to death. For all around use it is hard to beat a 4 wheel drive loader backhoe that you can remove and use the 3 point hitch and a good zero turn to mow with..... jim
Building a fence is making you a life time job mowing under it..... lol
/ Hole Digger Solution #13
I bought a 60 acre farm recently and I really don't plan on doing any traditional row farming so I was thinking a Ventrac might be a good solution for me. I am just about ready to pull the trigger but I need to dig fence holes for the estate and holes for an orchard that I am going to put in. If I cant find a ventrac solution I'm going to punt and just get a traditional tractor, probably a Kubota Grand L60 and be in debt for the rest of my life. So do any of you have a Ventrac based hole digger workaround? From my research it seems that at one time Ventrac had a post hole digger attachment but not anymore.
Thanks much!
Struck sells a remote hydraulic auger kit. It is their NH3A. (struckcorp.com)
/ Hole Digger Solution #15
Has anyone ever found specs for the Ventrac hydraulics? In order to think about building a hydraulic auger? I'd put it on the 3-point hitch.
/ Hole Digger Solution #16
How many acres are you fencing, and is it hilly, stony ground? Are you planning typical 4-5' wire fence with steel or wood posts, or a 5 rail board fence?
In either case a small older 15-25 HP tractor with a Post Hole Digger for $8-10K and maybe a 4-5' brush cutter would be a good start. then get a larger L series or similar for the rest of the work - and yes you need two tractors, and you came to the right place to let us spend your $.
We have six tractors and two skid steers and still run out at times.
KUBOTA KX057-4 EXCAVATOR (A59823)
KUBOTA KX057-4...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
2017 John Deere 6195R (A60462)
2017 John Deere...
2005 John Deere 7420 (A60462)
2005 John Deere...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
