Hold Me, Squeeze Me…Which, Or Both?
   / Hold Me, Squeeze Me…Which, Or Both?
Hi again, everyone, /forums/images/graemlins/smile.gif
I think I have digested and understand everyone's input so far...A couple more thoughts popped into my mind this morning…
BigAl added a “gentle hug” scenario to the picture, so I guess we now have “Hold me, Hug me, Squeeze Me” to consider. BigAl can adjust the amount of force his grapple applies, which sets the hug strength anywhere he likes between a gentle hold and a tight squeeze.
But when you think about it, once the control valve is centered, they all may become the same “Lock me in place” situation.
So it seems that if something is to be held under pressure, whatever is being held must be trying to spring back, after being stressed by the grapple due to the force the grapple applies when pushing against the item.
So a grapple that has more force available to its hydraulic cylinder, would have more ability to stress things, and would therefore be more likely “hold things” better.
When holding a rock, it could be that the bottom of the bucket is acting like a spring of sorts…
KennyV’s point of wanting sometimes to crush things illustrates an advantage of having more force available at the grapple than less. That makes a sense.
At this point, it seems to me that as long as things are designed so that at maximum system pressure one’s grapple does not self-destruct, having ample force exerted by the grapple is advantageous, and a strong push would be more desirable than a weak push.
It also seems that once cylinders are “locked” in position, regardless of how they are operated, if the control valves are equally good, the cylinders should hold position equally well.
What do you guys think? Is this reasonable?
Junkman,
I put that part about 100 psi under the red disclaimer because the background info that drove my question did not need to be given at all, but I thought it might be of interest.
A zero PSI example could have been used, such as a manually operated grapple that was moved by hand and latched in place.
The most definitive answer to your question was given by JerryG in that other thread where he said he had seen between 100 and 200 PSI system pressure in open center hydraulic systems at the lower end. I am paraphrasing what he said, but it is in his post. There were other comments in that thread by knowledgeable people pointing in that direction as well. There are other reasons, but those would be better left to another thread addressing this specific question. (Actually, Jerry might have posted that in a different thread…related to that original thread)
Thanks everyone! Keep those thoughts coming! /forums/images/graemlins/smile.gif
   / Hold Me, Squeeze Me…Which, Or Both? #12
Henro
I have to ask a question. Do you have a grapple yet? /forums/images/graemlins/tongue.gif
   / Hold Me, Squeeze Me…Which, Or Both? #13
Henro
I think it is the very occasional use that the grapple is doing anything more than keeping the items from falling out I.E. a hydraulic lid. There are times I clamp down and drag some things but generally the load is laying back against the bucket/grapple tines. Also there is an occasion of an item that is so big that the grapple must hold it also but gravity helps this quite a bit. So maybe you should add "block me" /forums/images/graemlins/wink.gif
   / Hold Me, Squeeze Me…Which, Or Both? #14
Ron I'm with you. Maybe we should all chip in and get Henro a grapple of his own so he knows how they really work out in the field. /forums/images/graemlins/grin.gif
JASTN70D nice pictures!
   / Hold Me, Squeeze Me…Which, Or Both? #15
Mike
I had to ask because we still have not seen pictures of the finished TnT project. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Did he bring pictures to the Eastern OH TBN meeting? /forums/images/graemlins/wink.gif
<font color="blue"> I had to ask because we still have not seen pictures of the finished TnT project.</font>
Ron, you got me there for a minute, because I remembered posting those pictures in that thread Here...
I think PineRidge has a great idea there, by the way. I'll prepare myself for a surprise at the next PA/Ohio get together. Wonder why I kind of got a feeling about what that surprise might be? /forums/images/graemlins/confused.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/blush.gif
Thanks to all for their input...I don't have a grapple yet, but sure might sometime in the future. Got a pretty good understanding of the practical aspects now. /forums/images/graemlins/cool.gif
   / Hold Me, Squeeze Me…Which, Or Both? #17
This retirement thing must be messing up my TBN time. /forums/images/graemlins/blush.gif I saw the QD pictures. But never viewed the cylinders.
I must have been out Christmas shopping. /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
Looks good. /forums/images/graemlins/cool.gif
   / Hold Me, Squeeze Me…Which, Or Both? #18
Henro or anyone who wishes to jump in,
I made a couple of very simple homemade drawings to try and illustrate what I think you are trying to explain. They are quite grainy as I had to resize them to get them to fit here. Pick them apart if you please but remember that they very basic. The first one shows the pump, then the priority valve that supplies the power steering the flow it needs when it is needed, then the tandem loader valve, next I just threw in an aux. valve and then the 3PH valve. If I understand just a little bit of hydraulics, there is a complete loop thru all of these devices with no valves shifted and the power steering sitting idle. With that scenario there should be no pressure anywhere in the loop other than a very low resistance pressure. Would I be safe to assume this?
   / Hold Me, Squeeze Me…Which, Or Both? #19
Ron the only thing I saw Henro bring to the TBN meeting was his sense of humor. I'm thinking his wife must be a saint to put up with him. /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif
   / Hold Me, Squeeze Me…Which, Or Both? #20
This drawing shows the same circuit with the closed center valve added in, I hope the way that it has been described.
Please explain to me if I've drawn this anywhere near correctly how you would have any pressure at point "AA" unless the loop was closed by anyone of the loop valves?
Steve
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
