Hobby Farmer in North Carolina
   / Hobby Farmer in North Carolina #1
Spainhour17
King, North Carolina
John Deere 2640 Refurbished
Long Model 5320M Front End Loader on 1972 John Deere 2640 Tractor?
   / Hobby Farmer in North Carolina #2
2640 if those are my choices.
   / Hobby Farmer in North Carolina #3
Spainhour
:welcome: to TBN
Where are you located? Click on your profile and add that info.. will help with answers to what question you have.. which I can't tell... what are you asking about a Long FEL on JD 2640.
Do you have that combo now ?
   / Hobby Farmer in North Carolina #4
:welcome: to TBN...enjoy.
   / Hobby Farmer in North Carolina #5
Welcome to TBN
If Long FEL has ind hyd control valve it needs to be for closed center type hyd's to operate correctly on a JD 2640. FYI JD 2640's were built '76-'82 not '72
Yes, Just bought Long Model 5320M and was wondering if it would fit on John Deere 2640 Tractor without a whole lot of fabrication and how does it match up with tractor?
   / Hobby Farmer in North Carolina #7
Dumb question; is the Long loader designed for a John Deere tractor? If not, I suspect a LOT of fabrication to make it work.
The hydraulics would be the easy part, if it has a closed center valve or can be converted to closed center.
   / Hobby Farmer in North Carolina #8
Guess I didn't read the "on" part, I thought is was "or".. Lots of fabrication I would suspect..
UNUSED FUTURE HYD HEDGE TRIMMER (A51248)
UNUSED FUTURE HYD...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
JOHN DEERE LOT NUMBER 19 (A53084)
JOHN DEERE LOT...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
Duetz Power Unit (A50120)
Duetz Power Unit...
