Hobby Farmer in North Carolina
   / Hobby Farmer in North Carolina #1
Spainhour17
King, North Carolina
John Deere 2640 Refurbished
Long Model 5320M Front End Loader on 1972 John Deere 2640 Tractor?
   / Hobby Farmer in North Carolina #2
2640 if those are my choices.
   / Hobby Farmer in North Carolina #3
Spainhour
:welcome: to TBN
Where are you located? Click on your profile and add that info.. will help with answers to what question you have.. which I can't tell... what are you asking about a Long FEL on JD 2640.
Do you have that combo now ?
   / Hobby Farmer in North Carolina #4
:welcome: to TBN...enjoy.
   / Hobby Farmer in North Carolina #5
Welcome to TBN
If Long FEL has ind hyd control valve it needs to be for closed center type hyd's to operate correctly on a JD 2640. FYI JD 2640's were built '76-'82 not '72
Yes, Just bought Long Model 5320M and was wondering if it would fit on John Deere 2640 Tractor without a whole lot of fabrication and how does it match up with tractor?
   / Hobby Farmer in North Carolina #7
Dumb question; is the Long loader designed for a John Deere tractor? If not, I suspect a LOT of fabrication to make it work.
The hydraulics would be the easy part, if it has a closed center valve or can be converted to closed center.
   / Hobby Farmer in North Carolina #8
Guess I didn't read the "on" part, I thought is was "or".. Lots of fabrication I would suspect..
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
91013 (A48082)
91013 (A48082)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
