HN1220
/ HN1220 #1
Anonymous Poster
Epic Contributor
The 1220 I'm considering has turf tires. If I want to switch to Ag tires, will I need wheels also? Will chains on the turf tires work instead? Are the wheel dealer only items? Is this tractor to "weak" to use the 5' rotory cutter effectively???TKS
/ HN1220 #2
DavidR R., so far as I know, if you change from turf tires to Ag tires, you do have to change wheels also (I think this applies to just about all tractors). I know from other messages that apparently quite a number of people use chains, but I never have. And you may be able to find used wheels somewhere other than the dealer.
Bird
/ HN1220 #3
What are the specs on a 1220? My 17 horsepower 4 wheel drive Kubota easily handles a 4 foot rotary cutter, and could handle a 5 footer in the grass (no heavy brush) that I cut. How much hp does the 1220 have, and is it 4wd?
/ HN1220 #4
DavidR R., according to tractortips.com, the 1220 has 17hp (14.5 PTO hp), and I don't know what the weight lifting limit is on the 3-point. So I would say you probably could use a 5' brush hog on very light stuff, but most likely should use a 4' one.
Bird
/ HN1220 #6
Wow, billboard size!/w3tcompact/icons/wink.gif Easy enough to read once you get through scrolling back and forth./w3tcompact/icons/smile.gif
Bird
/ HN1220 #7
Re: NH1220
DavidR R.,
Based on the info that Bird gave you about the HP, I would say that the 1220 is similar to the new TC18 which I own.
I have 18.5 hp but only 14 pto hp because I have a Hydro tranny. If it were manual, I'd have 15 pto hp.
My tractor is rated for 48" heavy duty rear blade, but I use a 60" Woods heavy blade and it works fine. It's also rated for a 48" rear finish mower, although I use a 60", dealer recommended, and it works great, albeit heavy - had to add almost 200 lbs weight to the front bumper.
However, mine is also rated for a 48" rotary and I use a 48" rotary which I bought this summer at dealer recommendation. Mine is a Woods XT148 light duty, I have only field to mow and it works great. I don't think that I'd want to put a 60" rotary on there since I plan to keep this tractor for awhile! The rotary mower jirates way more than the finish mower and IF you did hit something, I'd feel better with the right size deck on there.
I've read recommendations on here for 4-5 horsepower per foot of rotary. That would mean 20 hp or bigger for a 5' rotary. Some guys have way more hp than that, some probably have less. My TC18 would be between 4 and 5 hp per foot of rotary. Remember, narrower means more passes and more fun tractor time! /w3tcompact/icons/smile.gif
Good Luck, JimBinMI
/ HN1220 #8
PaulB,
Would you have wanted a 5 footer on there when you took your two joyrides down the slope?????
We're glad you only had the 4 footer on there!
JimBinMI
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
