Hitch arms lever question..
   / Hitch arms lever question.. #1
casingbill
What makes the lever spring into position after raising or lowering the lower hitch arms? I have a NH 1920 with 3pt hitch. The lever will raise or lower but has no tension. It just falls forward all the time, thereby lowering the arms on its own. Anyone have an idea on how this works? Thanks.
Bill
   / Hitch arms lever question.. #2
Are you asking about the lever by the seat that you move to raise and lower the three point hitch?
yes...exactly
   / Hitch arms lever question.. #4
I can't say for 100% certainty on your tractor, but almost all tractors have a nut that holds the lever on. The lever pivots on a bolt. There should be a spring that is compressed when the nut is tightened and that increases the tension on the lever.
   / Hitch arms lever question.. #5
Bill
Bill, as Jerry says, I think it is just a friction pad. I think you tighten a nut and it changes the friction enough to hold the handle in place.
   / Hitch arms lever question.. #6
Ditto.. I had a 1920.. and I likes my lever set pretty stiff.. see what you can do about adjusting it.. Floppy lever is no good..
Soundguy
great!..thx guys. for some reason i was overlooking the obvious and thinking it was something internal
   / Hitch arms lever question.. #8
Morning Jim. I'm glad you said that. I wasn't sure how his was made.
k...i just took a peek at it.....theres a crown nut on the shaft with a cotter pin going through the nut.....does this sound right?...I just need to tighten the crown nut?
   / Hitch arms lever question.. #10
Yep, that castellated nut is for doing just that: tightening only as much as needed to make your handle firm. I think you've found the solution.
As an aside...Many of the Boomers are sent from the factory with that nut too tight. It makes the position control lever so stiff, you can't feather the control. You want it to not move by itself, but also be able to make slight movements with gentle pressure from your hand.
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
Entyre Chip Spreader (A51573)
Entyre Chip...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
