hissing sounds from loader on down float
/ hissing sounds from loader on down float #1
nctacoma
Vermont
Kubota L4330
I have a Kubota L4330 and when I was lowering my loader(kubota 4365?)
today I pushed the joystick forward into the down float click and the loader went down with a hissing sound that I don't think I ever noticed before.
Does this sound normal or like it could be a problem?
I tried it a few other times and it also made the sound each time.
Any thoughts?
/ hissing sounds from loader on down float #2
Any thoughts?
In my opinion, normal if you float it down. All of them I have owned have done it.
James K0UA
/ hissing sounds from loader on down float #3
Mine hisses too, I think it's normal.
Great. Thanks. I am not going crazy and worrying for nothing then.
/ hissing sounds from loader on down float #5
Yep, normal.
/ hissing sounds from loader on down float #6
I'd worry if mine didn't hiss since all of them have.:thumbsup:
/ hissing sounds from loader on down float #7
I'm almost sure my loader manual states to only put it in float when the bucket is on the ground. If not I also get the hissing sound.
/ hissing sounds from loader on down float #8
I have the same tractor and in Vermont, too, and the loader hisses when lowered. Backhoe, too, only louder.
/ hissing sounds from loader on down float #9
My 3830 did it yesterday, I think it is normal. I am guessing in the float position the control valve for up/down is basically in a neutral position and let's oil free flow between pressure and return side
Steve
/ hissing sounds from loader on down float #10
Funny this comes up. Last night using my BX loader, I noticed the hissing sound, when load is being dropped, not in float. I do not recall ever hearing the hiss before. I'm wondering if I am having trouble.
So - since this thread addresses the hissing, while lowering in float mode, should it hiss when lowering, when NOT in float mode?
As always, thank you for your thoughts.
/ hissing sounds from loader on down float #11
IMO... When the fluid moves quickly, it makes a hissing sound as it circulates through the fittings and hoses. Perfectly normal.
/ hissing sounds from loader on down float #12
Will/can/does hiss when dropping in any mode.
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
2025 Future FT-46 Hydraulic Drum Mulcher Skid Steer Attachment (A61572)
2025 Future FT-46...
EAGLE FIBERGLASS BOAT (A63291)
EAGLE FIBERGLASS...
2022 Tesla Model 3 Long Range AWD Sedan (A61574)
2022 Tesla Model 3...
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
iDrive TDS-2010H...
