hissing sounds from loader on down float
/ hissing sounds from loader on down float #1
nctacoma
Member
Vermont
Kubota L4330
I have a Kubota L4330 and when I was lowering my loader(kubota 4365?)
today I pushed the joystick forward into the down float click and the loader went down with a hissing sound that I don't think I ever noticed before.
Does this sound normal or like it could be a problem?
I tried it a few other times and it also made the sound each time.
Any thoughts?
/ hissing sounds from loader on down float #2
Any thoughts?
In my opinion, normal if you float it down. All of them I have owned have done it.
James K0UA
/ hissing sounds from loader on down float #3
Mine hisses too, I think it's normal.
Great. Thanks. I am not going crazy and worrying for nothing then.
/ hissing sounds from loader on down float #5
Yep, normal.
/ hissing sounds from loader on down float #6
I'd worry if mine didn't hiss since all of them have.:thumbsup:
/ hissing sounds from loader on down float #7
I'm almost sure my loader manual states to only put it in float when the bucket is on the ground. If not I also get the hissing sound.
/ hissing sounds from loader on down float #8
I have the same tractor and in Vermont, too, and the loader hisses when lowered. Backhoe, too, only louder.
/ hissing sounds from loader on down float #9
My 3830 did it yesterday, I think it is normal. I am guessing in the float position the control valve for up/down is basically in a neutral position and let's oil free flow between pressure and return side
Steve
/ hissing sounds from loader on down float #10
Funny this comes up. Last night using my BX loader, I noticed the hissing sound, when load is being dropped, not in float. I do not recall ever hearing the hiss before. I'm wondering if I am having trouble.
So - since this thread addresses the hissing, while lowering in float mode, should it hiss when lowering, when NOT in float mode?
As always, thank you for your thoughts.
/ hissing sounds from loader on down float #11
IMO... When the fluid moves quickly, it makes a hissing sound as it circulates through the fittings and hoses. Perfectly normal.
/ hissing sounds from loader on down float #12
Will/can/does hiss when dropping in any mode.
2024 John Deere TX (A64119)
2024 John Deere TX...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
Caterpillar 955L Track Loader Service Manuals (A63117)
Caterpillar 955L...
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
