hinomotoE2304 shifter
   / hinomotoE2304 shifter #1
Ron Devous
Greetings - - The "plastic" ball-bushing that locates my gearshift disintegrated. Finding a replacement is a challenge. It's 1 1/4" in diameter (close) with a 9/16" hole to slip onto the shaft and a 5mm hole for the locator pin. Any one run across this before. "They" say it's the same tractor as the MF1030 and Deutz-Allis5230. Any body got any info for me?
   / hinomotoE2304 shifter #3
Try Eugene's suggestion first then maybe the local MF dealer. Same thing happened to my E2304 about 3 yrs ago and I found one at the dealer. Tell them it's for a MF1030. The only problem I had was installing it. You have to disassemble the gear shift assembly to slide the new bushing on and just couldn't figure out how to do that. I ended up splitting one side of the bushing and sliding it on the gearshift.
   / hinomotoE2304 shifter #4
The balls are no longer available from Agco. I'm in the process of making some.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
