hinomotoE2304 shifter
   / hinomotoE2304 shifter #1
Ron Devous
Greetings - - The "plastic" ball-bushing that locates my gearshift disintegrated. Finding a replacement is a challenge. It's 1 1/4" in diameter (close) with a 9/16" hole to slip onto the shaft and a 5mm hole for the locator pin. Any one run across this before. "They" say it's the same tractor as the MF1030 and Deutz-Allis5230. Any body got any info for me?
   / hinomotoE2304 shifter #3
Try Eugene's suggestion first then maybe the local MF dealer. Same thing happened to my E2304 about 3 yrs ago and I found one at the dealer. Tell them it's for a MF1030. The only problem I had was installing it. You have to disassemble the gear shift assembly to slide the new bushing on and just couldn't figure out how to do that. I ended up splitting one side of the bushing and sliding it on the gearshift.
   / hinomotoE2304 shifter #4
The balls are no longer available from Agco. I'm in the process of making some.
2018 AFE SSMM Disc Mulcher Skid Steer Attachment (A49461)
2018 AFE SSMM Disc...
Loader with IH Brackets (A50515)
Loader with IH...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2009 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A50854)
2009 UTILITY...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
