Hinomoto N209
/ Hinomoto N209 #1
htiek126
Southern Maryland
Iseki TA270F, Yanmar YM1510D, Mitsubishi MT2201D
Is any familar with the Hinomoto N209? I am debating importing an N209 that looks like it is in really good condition. Are there any similar US models? Are the parts similar to the E2004/E2304, especially for the engine and drivetrain?
/ Hinomoto N209 #2
I have had an N189 and an N239. Both were extremely nice.
They have shuttle shift, power steering and push button 4 wheel drive. They aren't anything like the 4 digit Hinomotos. I have a parts book for both of these models. I priced some parts just to see how hard they were to get. I got response on the parts. The electric 3 point is a little time consuming to figure out. Once you do it is pretty neat.
/ Hinomoto N209
Can I order parts from you? I have an E2004 with parts book, so I will check for common parts before selling the E2004. Do you know of FEL makes that would fit somewhat easily on the E2004/E2304 or N209? I want to transfer my old E2004 FEL or preferably buy new for the N209.
/ Hinomoto N209 #4
I have put Koyker loaders on E2304's before. I used a Deutz Allis 5220 mounting kit. I have to modify the front bracket because the mounting holes we off a little. The rear mount was perfect. They may have a front mount now. Koyker is really good about building kits for the greys.
/ Hinomoto N209 #5
From pictures I have seen the Massey 1030 looked to be very close to the E2002 or E2304. Are they not as close as the pictures look?
/ Hinomoto N209
I have the E2304/E2004 parts manual, and the parts are identical to the MF1030 parts for the front axle. I do not have the rest of the MF1030 parts manual to compare, but I believe they are mostly the same.
Does the Koyker FEL for the 5220 mount at the front bumper and rear axle like my E2004, or does it also mount in the center of the tractor?
/ Hinomoto N209 #7
Can you tell us more about the "shuttle shift"? Is this similar to the Yanmar "power shift"? Or is it more like the "sync-reverser".
/ Hinomoto N209 #8
The shuttle shift on my Iseki TA 262 and TA270 require the use of the clutch to operate. It isn't totally syncro. You need to come to a complete stop before shifting. It is nice, but not as flexible as the Yanmar " Power Shift". The shuttle on the N series uses the clutch also, but it can be shifted while moving.
/ Hinomoto N209
I am confused...
What is the advantage of the N209 Shuttle Shift as compared to the E2304 synchronized transmission if you still have to use the clutch?
/ Hinomoto N209 #10
You have as many gears in reverse as you do forward. The gear you use for forward and the one you use for reverse are the same ratio. Not slow forward and fast in reverse as in some tractors. It is in a handy location. Like I said " it ain't a power shift." It is just something different to play with. I use the clutch on my power shift tractors. I can control them better. It gets pretty jerky slammin gears at 2500rpm. Even though you can.
/ Hinomoto N209 #11
This "shuttle shift" sounds more like the (I think) JD "sync-reverser" which just allows syncronized shifting fwd to rev using the clutch. It effectively gives you a reverse gear for every forward gear.
/ Hinomoto N209
It sounds like the N209 may be the same as or similar to a Massey MF1125 or MF1140. In the used tractor buying guide, both tractors were made by Toyosha with 16F - 16R gears in 1991 to 1993. My Japanese tractor specs book shows the N209 was first made in 1990 (or 89?).
/ Hinomoto N209 #13
It sounds like we are on the right track. My importer is getting another N239 this week. I am loaded with tractors. If I can move one, I plan to snag it.
/ Hinomoto N209
I think the used tractor buying guide for the MF1125 and MF1140 is wrong. It has those models listed as Toyosha, and I read some of the posts from the MF forum, and the owners say they are Isekis, and JerryG also indicates that they are Isekis.
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2005 Butler pole trailer (A62679)
2005 Butler pole...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
